DFW Clutch Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Duck_Hunter, Dec 13, 2024.
  1. Dec 16, 2024 at 4:07 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Where’d you end up taking it?
  2. Dec 16, 2024 at 4:24 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    For 3,700 I think it depends on what was included in that quote. I just ordered almost every single part for a new clutch replacement including lines, master, slave, disc, flywheel, all new bolts, dowel pins, etc. All OEM. With shipping and tax I was somewhere around 1,800 iirc. 1,900 for labor is pricey but that works out to what...like, 12 hours of labor @ 150. If it was aftermarket parts, that raises the labor rate obviously. Either way, it's on the high end and glad they were able to get you fixed up for only the master and slave.
    Edit: just added it up...parts were 1,700 w/ shipping and tax.
    Duck_Hunter[OP] likes this.
  3. Dec 16, 2024 at 4:57 PM
    Duck_Hunter
    Duck_Hunter [OP] Well-Known Member
    Tejas
    2014 Tacoma TRD Off Road Manual
    ATC shell
    Tandem
    Naveronski[QUOTED] likes this.
  4. Dec 17, 2024 at 4:07 PM
    Duck_Hunter
    Tejas
    ATC shell
    Just picked it up. Night and day difference. Highly recommend Tandem Off Road in Haltom City if you’re in the DFW area.
    Hans_Gruber and Naveronski like this.
  5. Dec 17, 2024 at 5:12 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    Tandem offroad was a good choice. Great group of guys.
    They also have a Youtube channel they put some of their builds and activities on.
  6. Dec 19, 2024 at 6:56 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I ordered an Aisin replacement clutch kit ....disk, pressure plate and throw out bearing and plastic alignment tool from Amazon. I had an independent garage install. They also found the slave cylinder was leaking slightly and the front transmission seal was weeping. They changed them. Cost, $895 for their labor and additional parts. I also noticed that they had to replace two bolts on the drivers side exhaust manifold . They must have snapped when dropping the exhaust system. Irrc, the parts from Amazon were about $300.00. This was in July of 2024. The clutch still had plenty of life left in it and the flywheel was fine at 115.000 miles. The throw out bearing chirp was the issue.
  7. Dec 19, 2024 at 4:29 PM
    Duck_Hunter
    Tejas
    ATC shell
    I’ll check that out!
