Diagnose me/Fix me
Discussion in 'Garage / Workshop' started by Mitch, Feb 16, 2013.
  1. Feb 16, 2013 at 3:56 PM
    Mitch
    Mitch [OP] Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
  2. Feb 16, 2013 at 3:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It looks like it was run over by a dump truck.
  3. Feb 16, 2013 at 3:58 PM
    Mitch
    Mitch
    Spokane, WA
    I got the video to upload
  4. Feb 18, 2013 at 9:59 AM
    Mitch
    Mitch
    Spokane, WA
  5. Feb 18, 2013 at 10:01 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Video is private
  6. Feb 18, 2013 at 10:10 AM
    Mitch
    Mitch
    Spokane, WA
    God dam it. Hold on
  7. Feb 18, 2013 at 10:16 AM
    Mitch
    Mitch
    Spokane, WA
  8. Feb 18, 2013 at 10:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Still says the video is private.
  9. Feb 18, 2013 at 10:18 AM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
  10. Feb 18, 2013 at 10:18 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    We still can't see your video.
  11. Feb 18, 2013 at 10:26 AM
    Mitch
    Mitch
    Spokane, WA
    Okay I think I fixed it
  12. Feb 18, 2013 at 10:29 AM
    ppham444
    Phuong
    Portland, OR
    Did you have old fuel still sitting in the mower? If so, it probably gummed up your internals. I recommend replacing your spark plug every new cutting season.
  13. Feb 18, 2013 at 10:29 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Does it die, if you give it more throttle?
  14. Feb 18, 2013 at 10:37 AM
    Mitch
    Mitch
    Spokane, WA
    Yeah i forgot to burn it down in September.
    i put a new spark plug in on Saturday and it still runs like that. Can I just let it burn all the gas? Then replace with new gas?
    Nope. That is full throttle
  15. Feb 18, 2013 at 10:37 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    sounds like bad gas or a partially clogged pilot jet maybe. Try reving it up.
    edit: just saw that's full throttle, Im betting clogged main jet.
  16. Feb 18, 2013 at 1:52 PM
    Mitch
    Mitch
    Spokane, WA
    How can i clean that?
  17. Feb 18, 2013 at 4:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Pull the carb off, and remove the float bowl. Inside there you'll find 2 jets, a main and a pilot. The main is usually the big one that isn't inside a long tube. Unscrew it with a flat blade screw driver and clean it till you can see through it. While in there I would clean up the float valve, pilot jet, etc. Old gas really screws things up inside a carb.
  18. Feb 18, 2013 at 4:42 PM
    andjenliang
    andjenliang Well-Known Member
    Andew
    LBC/OC/LAX
    10 DCSB PreRunner V6 TRD Off Road
    Stock
    would spraying carb cleaner help?
  19. Feb 18, 2013 at 4:42 PM
    Mitch
    Mitch
    Spokane, WA
    Okay. Thanks. Should I run the motor till the gas is gone or pull everything and suck the gas out?
  20. Feb 18, 2013 at 10:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    pull the tank off and dump it. Also check out youtube for some tips on small engine carb rebuilds.
