Diagnose me/Fix me
Discussion in 'Garage / Workshop' started by Mitch, Feb 16, 2013.
  1. Feb 18, 2013 at 10:40 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You're cutting grass already ?
  2. Feb 19, 2013 at 8:10 AM
    Mitch
    Mitch [OP] Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Okay thanks
    Its starting to grow already. Plus it will help with the pup.
  3. Feb 21, 2013 at 8:41 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    I recently had to put a new diaphragm into a fairly new Briggs carb. It was running the same way in the video. If you pull the carb apart and the diaphragm gasket has any wrinkles, that could be the culprit if the jet(s) are clear.
  4. Feb 22, 2013 at 9:12 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Carb is probably gummed up. That's what happens when you leave Gas w/ ethanol in it over the winter.
    Take the carb off and clean it out as previously stated.
    I own a landscaping/lawn care business so I have a little experience with this. At the end of each season, I mix stabil in in my gas tanks and run that through my equipment the last week. Then I drain all of the gas out of the tanks and run the equipment til it dies.
    I also run a bottle of gas treatment through the first tank of gas in the spring.
    Also, it wouldn't hurt to replace the spark plug too. I replace the plugs every season on all of my equipment. They're so cheap anyways... why not.
  5. Feb 26, 2013 at 7:20 AM
    Mitch
    Mitch
    Spokane, WA
    I pulled the carb, dumped the gas, inspected the carb and it looks clean. I'm gonna pull it again next weekend. I out new gas in and it still runs like it was.
  6. Feb 26, 2013 at 7:51 AM
    Bistineau
    Bistineau Well-Known Member
    Bossier Parish La.
    2013 Prerunner SR5
    Para-bolic mirrors on the outside rearveiws.
    Add a heavy dose of carb cleaner to the fresh gas in the tank and let it run for awhile to see if that helps. I recommend B-12 ChemTool, but most name brand cleaner should do, just make it a heavier dose than what is on the label, more won't hurt a thing as long as it's not straight carb cleaner and no gas. Don't get something that say fuel treatment, make sure it is a carbuerator/fuel injector cleaner. If that doesn'rt do it, then disassembly for more in depth cleaning will be needed.
  7. Mar 2, 2013 at 4:09 PM
    Mitch
    Mitch
    Spokane, WA
    Heres an update. Last weekend I tore it apart. Dropped the tank, inspected and wiped down the carb. Put new gas in, but it din't help. So today I went to Lowes where I bought it and talked to them. They recommended a carb cleaner and an Ethanol treatment. Tore apart the motor again, sprayed a ton of carb cleaner all over the carb. Dumped the gas put new gas in (just a small amount to run the motor dry)
    It ran like crap for 2 minutes then ran like a top. Until I stopped to fill the tank. Now its still sputtering so I'm letting it run through the half tank of gas that I out in it. To see if the treatment works.
    Here is the old gas that I let sit in there compared to the gas I dumped today. No shit it wouldn't run correctly.
    Here is how it was running before I added more gas
    http://youtu.be/nuTszHhqyc8
  8. Mar 2, 2013 at 4:57 PM
    Mitch
    Mitch
    Spokane, WA
    Alright I think I figured this out. The butterfly valve that regulates the fuel input isn't opening all the way, when I pull the spring it opens up and sounds great. And once I play with the valve spring the valve stays open. And the motor runs perfectly
