Diagnose my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by SAB_0010, Nov 30, 2016.
  1. Nov 30, 2016 at 2:59 PM
    SAB_0010
    SAB_0010 [OP] Well-Known Member
    Seth
    1996 Tacoma 3.4l 5-speed
    I have been having problem after problem with the truck since I got a different daily driver. Unless I let the truck warm up forever, it will not go past about 2500 rpm unless I ease my foot off the pedal and it will get a little better. I have cleaned the maf but it hasn't helped this time and some others suspect the converter is stopped up but I think there is more to it. Today when I started the truck for the first time since Saturday it was extremely rough and shaking. I shut it off and started it back and it was pretty much normal. Any ideas?
  2. Nov 30, 2016 at 3:12 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Miles? Plug wires on the 1st gens w/V6 usually need to be replaced every 80K. The symptoms will make you think it's being starved for fuel.
  3. Nov 30, 2016 at 4:08 PM
    SAB_0010
    Seth
    284k. I've got new plugs to put in it but I didn't get wires. I haven't changed the wires since I got it about 50k ago
  4. Nov 30, 2016 at 4:41 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Check fuel pressure, tap on the converter to see if you have a loose brick, or hook a pressure gage to the exhaust upstream and measure exhaust back pressure. If it were converters, they tend to get worse the hotter they get...
  5. Nov 30, 2016 at 4:51 PM
    SAB_0010
    Seth
    I took the o2 sensor out and I couldn't tell much of a difference. I think it only felt like it had a little more power because of the loudness. The truck does become noticeably weaker after extended amounts of highway driving (30 minutes or so). I don't have a fuel pressure gauge but I'll try to locate one this weekend.
  6. Nov 30, 2016 at 4:56 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Is there a CEL?
  7. Nov 30, 2016 at 5:00 PM
    SAB_0010
    Seth
    Not at the moment. It will occasionally pop on for the oxygen sensor. throws the too lean code
  8. Nov 30, 2016 at 5:08 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Sounds like fuel pressure to me. Your air filter is clean I am assuming...
  9. Nov 30, 2016 at 5:17 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Definitely change out the wires.
  10. Nov 30, 2016 at 5:24 PM
    SAB_0010
    Seth
    Yeah I blew it out with the compressor and cleaned the throttle body and maf 2 or 3 weeks ago to try to help with the difficult accelerating issue.
  11. Nov 30, 2016 at 5:26 PM
    SAB_0010
    Seth
    I'll pick up some
  12. Nov 30, 2016 at 6:38 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Check your cap and rotor and while you're at it check the distributor coil for any obvious signs or cracking, arcing or burning. A bad coil can exhibit different symptoms for different engines and especially when it gets hot like during highway driving. You can check the resistance following the repair manual procedure/specs. And a used denso coil/distributor often is better than an aftermarket.
    TomTwo likes this.
  13. Nov 30, 2016 at 6:43 PM
    strmtrooper1
    strmtrooper1 Well-Known Member
    Jeff
    2015 TRD Sport DCSB
    OME Lift, 33" Goodyear DuraTracs
    My 99 with 230k had a similar problem, wouldn't rev past 3000, rough idle, no CEL...threw a shit ton of parts at it with no luck. turned out to be bad injectors. All six were plugged with rust. ran like a new truck after I rebuilt them
  14. Nov 30, 2016 at 6:44 PM
    SAB_0010
    Seth
    I haven't checked the distributor but I will when I work on it this weekend.
  15. Nov 30, 2016 at 6:48 PM
    SAB_0010
    Seth
    I was going to replace them if plugs and wires don't solve the problem and the fuel pump
  16. Dec 4, 2016 at 11:54 AM
    SAB_0010
    Seth
    Changed the plugs and it seemed to do a little better. I will know for sure in the morning to see how it acts after it sits all night. Meant to check the fuel pressure but it was cold and raining and I had already put on ball joints and got pissed off at them so I stopped for the day.
  17. Dec 4, 2016 at 12:02 PM
    Admiral Awesome
    Admiral Awesome IG:Bucklaooooo
    anthony
    Houston Texas
    2012 DC TRD LT
    Camburg 3in LT kit fox shocks/bypasses 315-75-16 Scs f5 wheels gunmetal 16x8 Prinsu rack 40in heretic light bar Cali raised ditch light Baja squadron pros McNeil fiberglass fenders Adv fiberglass bedsides Volant intake
    Clean the throttle body?
  18. Dec 4, 2016 at 12:02 PM
    SAB_0010
    Seth
    Yeah
  19. Dec 20, 2016 at 5:37 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  20. Dec 20, 2016 at 8:26 AM
    SAB_0010
    Seth
    Thanks, new plugs seemed to help a little but it still has a low rough idle at around 600 rpm after warm and it is very weak if i don't give it time to warm up. I'll pull the ICV off and clean it up a little better and I never did unplug the ecu when I cleaned everything so I'll do that. A couple vacuum lines have cracks in the end but I don't think they could be causing much of a leak but I'll try to find out how much of what I need and replace them as well. If none of this works I'll get a new ICV, I just don't want to toss in another $250 when I still need to take care of the clutch and timing belt and a few other miscellaneous things.
