Diagnosing belt chirp
Discussion in '1st Gen. Tacomas (1995-2004)' started by sbuck, Sep 25, 2019.
  1. Sep 25, 2019 at 7:33 PM
    sbuck
    sbuck [OP] Active Member
    2001 Tacoma
    2001 Toyota Tacoma
    2WD 2.4L 4cyl
    92k Miles
    I have a chirp/squeak coming from the area near my power steering belt.
    Happens consistently - both from a cold start and when warmed up.
    When I spray it with water the noise goes away, but quickly comes back.
    All 3 accessory belts (power steering, AC, alternator) are less than a year old; replaced about 1k miles ago. Continental belts.
    It's just recently started (i.e. it didn't start after putting on the new belts)
    Don't have a calibrator for the tension, but it doesn't feel loose.
    Video below of the noise and water test.
    My next test will be to remove the belt and try spinning the power steering pulley manually, checking for play/noises, but was curious to hear what others think/where they would start.
  2. Sep 25, 2019 at 7:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Either needs a new ps belt or need to adjust the tensioner
  3. Sep 25, 2019 at 7:40 PM
    sbuck
    2001 Tacoma
    Is it common for belts with < 1k miles to need to be replaced? Defective belt?
  4. Sep 25, 2019 at 7:43 PM
    anthony250f
    Anthony
    San Diego, CA
    I wouldn’t say it is common, but it has happened to me before. Luckily they are VERY easy to replace yourself
  5. Sep 25, 2019 at 7:54 PM
    sbuck
    2001 Tacoma
    Agreed! (I was the one that replaced them 1k miles ago :)
  6. Sep 25, 2019 at 9:21 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    It's usually the tensioner bearing . Get WD40 with the straw tip and a shot directly on it to check .
    Black DOG Lila likes this.
