Diagnosing Worn Upper Ball Joints 1998 TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, May 3, 2012.
  1. May 3, 2012 at 8:37 AM
    skeezix
    skeezix [OP] The Voice of Experience (mostly negative)
    Colorado
    1998 Limited
    How can I, as a user and not as a mechanic, check the upper ball joints? The truck has 60K miles on it. I just replaced all shocks, the LBJs and the SR.
  2. May 3, 2012 at 8:40 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Check if the boots are cracked then jack up the wheel and go back and forth to see if there's a lot of play. If there is then you need new uppers. But why not just replace them you seem to have replaced the other ones
  3. May 3, 2012 at 8:46 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yeah the uppers are only 12 bucks unlike those stupid lbj
  4. May 3, 2012 at 8:51 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    my passenger upper boot is screwed and its leaking massive amounts of grease...the 12 new bj is not the problem. it is replacing it, which from what everyone is telling me is almost something you just take to a shop and have them do.
    you can test your bjs by seeing how much play they have with a pry bar. but then again you have to know how much play is too much. with 60k unless they are leaking or dry rotted or visibly ruined you should be fine
  5. May 3, 2012 at 9:00 AM
    BAMFTACO
    Juan
    If they make moog ballpoints I'd recommend those there greasable and last longer
  6. May 3, 2012 at 9:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Aren't the ball joints pressed in? Rent the tool from autozone, if so.
  7. May 3, 2012 at 9:46 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    When you separate the knuckle from the ball joint, there will be noticible slop. The joint should be difficult to move by hand.
    Basically, if the boot is cracked, it's days are numbered. Dirt and water can easily enter and accelerate wear.
    Replace them in pairs. If you have the money, replace all the ball joints and tie rods at one time.
