Diagnostic check????
Discussion in '4 Cylinder' started by spaid84, Feb 24, 2010.
  1. Feb 24, 2010 at 4:04 PM
    spaid84
    spaid84 [OP] New Member
    Rob
    PA
    95 tacoma
    i got a 95 4cyl 5spd tacoma 4x4 how do i check the check engine light codes...what scanner do i use and where do i get it?? any help greatly appreciated thanx ....Rob
  2. Feb 24, 2010 at 4:24 PM
    roddyrod72
    roddyrod72 Well-Known Member
    Greenville, KY
    2018 MGM TRD OR DC 6MT
    ICON Stage 2 coilovers, ICON Rebound 17x8.5, SPC UCAs, Mickey Thompson Deegan 33s
    If you go to an Autozone or similar parts store, they will scan it for free. It might not be as detailed a scan as a pay shop would be, but it's free. For instance, they might tell you that you have a bad o2 sensor, but the scan won't tell you which one. If they give you a trouble code, come back home and Google it and most likely you will find your answer.
  3. Feb 24, 2010 at 5:03 PM
    spaid84
    Rob
    PA
    95 tacoma
    thanks but i actualltwork for autozone my truck is obd 1 autozones scanner is only obd 2
  4. Feb 24, 2010 at 5:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yours is a 95?
  5. Feb 24, 2010 at 7:04 PM
    roddyrod72
    Greenville, KY
    My bad, I thought OBD2 was 95 and newer. Is yours a 95 or 95 1/2?
  6. Feb 24, 2010 at 7:25 PM
    spaid84
    Rob
    PA
    95 tacoma
    yeah a 95.....how do i tell if its a 95 or a 95.5?? and when i look under the hood i can see the diagnosis connector rite at the front of the intake
  7. Feb 24, 2010 at 7:40 PM
    roddyrod72
    Greenville, KY
    If it is a 95, it would be a Toyota Pickup...not a Tacoma. The Tacoma's started in 95.5. I'm not sure if it makes a difference in the OBD version, however.
    On my 97 Tacoma, it also has the diagnostic connector near the intake as you mentioned. I wonder what the difference is between the connector near the intake vs the connector under the steering column???
  8. Feb 25, 2010 at 6:21 PM
    spaid84
    Rob
    PA
    95 tacoma
    okay then it is a 95.5 cuz it is deff a tacoma. i pulled the cover off the diagnostic plug under the hood and it is deff not obd2. so back to my original ? is there an obd1 scanner out there for it?
