Diamond E-locker Full Float axle housing
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by TMFF, Aug 22, 2019.
  1. Aug 22, 2019 at 8:34 AM
    TMFF
    TMFF [OP] Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Diamond Full Float axle housing.
    This is a fabricated housing that fits the E locker diff and uses D44 outer hubs.
    The center section is 1/4 steel with a 1/2 face plate, Axle tubes are 3.5" 3/8 wall tubing.
    The width is 60 WMS
    The calipers and pads are near new with 5K on them.
    Brake lines and brakes are included.
    NO Third member is included!!!!
    2 sets of drive flanges
    3 chromoly axles, 2 are in good shape, 1 the outer splines have rolled slightly. It would make a good spare still.
    Has seals it inner axle tube seals. https://sealsit.com/product/economy-axle-seal/
    The spring pads are setup to bolt into a 1st gen Tacoma currently.
    The shock mounts were for a relocation to fit a 10-12" shock under the bed on my truck.
    Used U bolts and homemade U bolt plate can be included if needed.
    Shipping will have to be freight only because of size.
    More info about Diamond axles
    located in Thornton, CO
    $800
  2. Aug 22, 2019 at 8:35 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  3. Aug 22, 2019 at 8:36 AM
    blind_1560
    blind_1560 Well-Known Member
    nick
    Any idea if this would fit a 3rd gen 4 runner?
  4. Aug 22, 2019 at 8:50 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    The width and bolt pattern would match. You will have to fabricate all the spring perches and link mounts for this to work.
