Diamond rear axle install
Discussion in '1st Gen. Builds (1995-2004)' started by Ritchie, Dec 12, 2016.
  1. Dec 12, 2016 at 8:48 PM
    Ritchie
    Ritchie [OP] Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    On August 25th, I ordered a Diamond rear axle with all measurements to OEM specs. I picked it up at the shipping company last Monday.
    I must say, in its raw form, it's a piece of art. I detailed it prior to install on Saturday and on Sunday, proceeded to complete the install.
    Pretty straight forward but I did some things out of sequence as I did not have any instructions for the install.
    All went well with the exception of the DS inside U-bolt. The welded DS brake line tab is 3/4" further outward than the PS. A simple twist on it with a crescent wrench was the remedy for that issue. I do have a small brake fluid leak at the top of the 'T' where the extended brake line attaches. This issue will be cured with the new that I ordered from Marlin Crawler which I'll install Saturday morning.
    The brakes have never been better thanks to the Wilwood adjustable proportioning vale. Once the rear disc pads work in, they will be better.
    As this piece is a completely assembled unit, you will need e-brake cables from a 2010 FJ Cruiser, plus the bracket where the cables terminate. The bracket is back-ordered so currently my e-brake is non-functional.
    Anyway, here are some pics of where I'm at to this point:
  2. Dec 12, 2016 at 8:50 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Holy shit man badass!
  3. Dec 12, 2016 at 8:53 PM
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    Fucking beautifully badass! Looks great man!
  4. Dec 12, 2016 at 9:09 PM
    Ritchie
    Thanks guys.
    I am so stoked with the outcome. The best part are the rear disc brakes... it stops on a dime and gives change. The Wilwood unit definitely adds to this. No more nose diving when hitting the brakes. It truly hunkers down and gets with it.
    TacoVio likes this.
  5. Dec 12, 2016 at 9:12 PM
    icallhertaco11
    Jamie
    Texas
    I was just wanting to go to disc, not necesarily the whole axle because money haha how hard would his swapping to disc be?
  6. Dec 12, 2016 at 9:15 PM
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    BEAUTIFUL !
  7. Dec 12, 2016 at 9:16 PM
    Ritchie
    I suggest calling Brian @ Front Range Off Road (FROR). Their parts are on point and easy to figure out to install.
    The best part is, I didn't need to replace any of my OEM master cylinder components, which involves cash. I do have the 231mm Tundra discs up front and no changes in pedal feel.
    Do these mods and you'll be good to go.
  8. Dec 12, 2016 at 9:20 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Its not super easy. I inquired about it when I ordered my chromo shafts from low range.
    They hadnt had a kit in quite a while even though the website had them.
    I think the run a gm caliper and you need a larger master cylender from a seqoia or fj.
    That being said....if you are handy with tools and have some knowledge of brakes, it shouldnt be that bad.
  9. Dec 12, 2016 at 9:21 PM
    Matic
    Tricky Dick
    Easley, SC
    Lookin sweet OP.
  10. Dec 12, 2016 at 9:23 PM
    Matic
    Tricky Dick
    Easley, SC
    Odd. i had always read that the master had to be replace. Possibly because you already have the tundy brakes there was no need?
  11. Dec 12, 2016 at 9:28 PM
    Matic
    Tricky Dick
    Easley, SC
    Nm. the trail gear kit requires no change in master cylender.
  12. Dec 12, 2016 at 9:34 PM
    icallhertaco11
    Jamie
    Texas
    Well that's good. I wouldn't touch my master cyclinder by any means, I'm so cautious with brakes don't wanna take a chance.
    Ritchie[OP] likes this.
  13. Dec 12, 2016 at 9:37 PM
    Matic
    Tricky Dick
    Easley, SC
    Im going to guess that the kit from fror (which I cant seem to locate on there webpage) is probably the trail gear disc brake kit.
    Can be had for $399.
  14. Dec 12, 2016 at 9:38 PM
    Matic
    Tricky Dick
    Easley, SC
    OP. did you go with chromolly rear axles?
    Or do you have abs?
  15. Dec 12, 2016 at 9:46 PM
    Ritchie
    ... you think like I did.
    These parts are all Toyota with the exception of the welded (FROR) flange onto the axle tube.
    There are no fail gear parts on this axle.
    After I did the front Tundra brake upgrade, there was no difference in the pedal feel.
    After this upgrade, again, no change but the brakes are much better.
    I completely/ entirely eliminated the ABS system, and yes, the axles are chromo.
  16. Dec 12, 2016 at 9:49 PM
    Ritchie
    Low range is a different story... my parts are from Front Range Off Road. These guys are on point, not to say Low Range isn't, its just that I haven't dealt with them like I have Front Range.
    Matic[QUOTED] likes this.
  17. Dec 13, 2016 at 6:47 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    That is the same setup I want to go to!
    I have a Diamond that the PO converted to D44 based FF, it works well but I lost the E-brake. I've dealt with it for a few years and even tried a tcase parking brake, it worked but not very good.
    These are the best pics I have seen of the Drotor, I haven't seen the backing plate he makes fully.
  18. Dec 13, 2016 at 7:02 AM
    Ritchie
    ^^ the e-brake is non-functional at this time. I am waiting for a back-ordered bracket to be delivered.
    It appears as I will need some custom cable ends at the front. The DS cable is very long and the PS is close to the OEM location.
    Part numbers for the cables:
    Driver: 46430-35563
    Passenger: 46420-35773
  19. Dec 13, 2016 at 7:12 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Do they both go back to the split under the cab? VS the split being on the axle? The length might not be much of an issue with the longer trucks. Do you have a PN for the bracket? Think one could be built?
    Thanks for the PN's!
    I emailed FROR a few weeks back about cutting my ends off and welding the toyota ones on, never got a reply. :confused: Maybe he slammed and doesn't want to deal with reworking an axle. I guess I will have to order parts and do it myself even though I'm only a couple hours drive from him.
  20. Dec 13, 2016 at 7:49 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Sweet! did you get the 8.4, or 9.5 diff? rear discs are the shit for sure!
