Diamond rear axle install
Discussion in '1st Gen. Builds (1995-2004)' started by Ritchie, Dec 12, 2016.
  1. Dec 13, 2016 at 8:00 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    That is a completely different kit that FROR. That kit does not have an e-brake.
    The FROR kit is a 4runner/FJ rear kit adapted to fit the pickups. The trail gear kit is a GM kit adapted to fit pickups.
    BTW that axle is beautiful.
    Ritchie[OP] likes this.
  2. Dec 13, 2016 at 10:46 AM
    Ritchie
    Ritchie [OP] Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    I kept the 8.4 due to already having the locked ARB setup. The brakes are amazing.
  3. Dec 13, 2016 at 10:51 AM
    Ritchie
    Once I have the bracket, I'll post the part number.
    If I were you, I'd have FROR cut/weld the new ends since you are so close to them.
  4. Dec 13, 2016 at 3:20 PM
    Ritchie
    Each cable is separate and terminate at the bracket. From the photos I've seen, a separate cable is between the cable ends in the bracket and will attach to the OEM lever configuration. This is where the McGyver'ing will come into play.
    I don't have the bracket yet so I can't say if one can be built or not but, I don't see why not.
    I'll post a photo once I have it.
  5. Dec 20, 2016 at 3:17 PM
    Ritchie
    So I am still waiting for the bracket to arrive.
    Meanwhile, I did acquire this 'T' setup. I found some metric all-thread and 3 flange nuts to make it work after I get the bracket.
    I will pull the DS cable from the housing, cut the housing where I need, then splice it together with some industrial electric line shrink tube. I'll do this in two stages. After, I will modify the actual cable end, solder and hopefully be done with this.
    When I picked up the all-thread, an actual Toyota tech was in line in front of me. I told him of my plans and he said I was on the right path.
    More to follow.
    TMFF likes this.
  6. Dec 20, 2016 at 3:19 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  7. Dec 21, 2016 at 9:30 AM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    I'm so ready for my rear diamond project to be done lol
    Thanks for the motivation @Ritchie
    The axles are for sure a masterpiece. It's a shame to even paint them. 20161129_074030_zps3vfdjdwd_dd5ccf9d7d4696152cc00e1d66713f6522189c17.jpg
  8. Dec 24, 2016 at 7:31 AM
    Ritchie
    I now have the bracket that the cable housing ends clip into.
    I'll get this installed once the rain stops.
    It'll be nice to have a parking brake again.
  9. Dec 31, 2016 at 6:06 AM
    Ritchie
    I just went through your specs link, cool. How is the project coming along?
    I am hoping to gain some ground this weekend (weather permitting) in getting the parking brake close to being functional.
  10. Jan 3, 2017 at 6:58 AM
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    I put it all together and mounted it over the weekend. I still have to put the shocks back on, hook up the brake line and proportioning valve, and tighten all bolts down. Along with some other odds and ends, I should be able to get it back on tires this week. It's been a fun learning process, but doing it all myself has made the project last longer than I hoped. If I learned anything it's that I should have mounted the bare housing first then built everything while it was on the truck lol. It's a heavy beast.
  11. Jan 3, 2017 at 2:49 PM
    Ritchie
    I was able to work on the parking brake this past weekend.
    I shortened the DS FJ Cruiser cable housing 32". The end of the cable will be used so I cut it and left a 6"-8" whip on it which has enough overlap with the cable that is connected inside the Drotor. This overlapping will allow me to clamp the two together. If this works, great, but if not, I'll need to be creative and come up with something else.
    The metric piece of all-thread was also cut and I have about 3" remaining that goes through the parking brake swivel point.
    The bracket I made is 4"x 3", bent in the middle. The holes are 9/16". Tight fit but eventually went in enough to get the spring type tabs to spread and lock. I did need to grind off 1/4" on the vertical side to get clearance from the fuel tank.
    I re-used the OEM parking brake bracket hole & bolt to bolt this new bracket in place. This required me to drop the fuel tank 2" to get my hands between the frame & tank.
    The routing is perfect and does allow for flex.
    The pic with the 2 overlapping cables... where the zip ties are is where I will install the clamps.
    More to follow.
    TMFF likes this.
  12. Jan 3, 2017 at 2:56 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    WOW
  13. Jan 9, 2017 at 2:06 PM
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    Nice headway on the parking break, looking good!
    I got everything all finished up this past weekend :D
  14. Jan 10, 2017 at 4:33 AM
    Ritchie
    Great news... any pics?
    How will you set up the parking brake?
  15. Jan 10, 2017 at 6:35 AM
    #35
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    No parking brake for now.. This setup wont allow for it. I can't remember the last time I used it anyways. Worse case scenario I'll jam something between my seat frame and the brake pedal and push the electric seat forward to keep the brake pedal down before I turn the truck off :laughing:
    ramonortiz55 likes this.
  16. Jan 10, 2017 at 6:46 AM
    #36
    aeok18109
    aeok18109 Well-Known Member
    Ernesto
    1996 Blue Tacoma 4wd 2.7L 5sp
    and kill your battery in the process lol. temporary fix sure, but for those who live on a hill like i do, leaving it in gear and turning the wheels isnt 100%. i need an E brake.
    awesome setup otherwise :D
  17. Jan 10, 2017 at 2:39 PM
    #37
    Ritchie
    That looks awesome.
  18. Jan 11, 2017 at 6:35 AM
    #38
    JWaldz
    Waldo
    Colo Springs
    99 4Runner LTD
    True.. I guess my future plans will be searching for a dependable line-lock to use in some situations. Otherwise, maybe further down the line when I SAS this thing I can look into different transfer case options that also allow for a transfer case brake. In the mean time, it's resting against trees (or other peoples vehicles ;) )lol.
    Thanks dude
  19. Jan 11, 2017 at 6:38 AM
    #39
    ramonortiz55
    Ramon
    Texas
    stock
    JWaldz[QUOTED] likes this.
  20. Jan 11, 2017 at 9:37 AM
    #40
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I have a ballistic tcase brake that actually works. On my J shift case. The down side is lots of adjustments to keep from making too much noise. I had to beef the mount some and build a new lever to go from the e brake on the frame to the t case.
