Diamondback .380
Discussion in 'Guns & Hunting' started by FLtaco, Dec 27, 2011.
  1. Dec 27, 2011 at 8:42 AM
    FLtaco
    FLtaco [OP] Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    Got a diamond back 380 for Christmas. It's my first cc pistol and I've read alot of online reviews saying its ammo sensitive. I've put close to 50 rounds threw it with FTF and FTE occurring alot. I was using cheap ammo and forums online say that could be culprit. Anyone own one? If so what ammo do you use? Any FTE or FTF happening to you?
  2. Dec 28, 2011 at 8:27 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Bump anyone
  3. Dec 28, 2011 at 8:31 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    If you've read that it's picky with ammo, you used cheap ammo, and had a lot of ftf/fte I would try better ammo and see the results you get. If you have problems with better ammo, I would check in with the people you bought it from.
  4. Dec 29, 2011 at 4:05 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Thanks for the worst response ever. I kind of planned on using better ammo next time. the question wasn't what should I do?it was does anyone else own one and experience same problems?
  5. Dec 29, 2011 at 4:57 AM
    CaliforniaKid
    CaliforniaKid Well-Known Member
    Jim
    Central California
    2010 Tacoma 4x4 Dbl Cab TRD OR
    Under Cover Bed Cover
    Ya buy a cheap gun, shoot a lousy 50 rounds of cheap ammo and are an asshat to the only person to respond. I'm sure ya won't like this response either. Put another 300 rounds through it or so to break it in and get back to us if anyone will listen.
  6. Dec 29, 2011 at 5:18 AM
    differential
    differential Member
    Dallas
    Black Pre Runner
    Run some good ammo through it (Winchester white box) and see how it does after about 300 rounds. After that try some hollow points. If it doesn't work flawlessly, take it to a gunsmith or downgrade it to a fun gun and get something reliable for cc.
    I don't know much about the diamonback, but if it's a $100 gun or a $10,000 gun, don't bet your life with a finicky piece.
    I don't mean to derail this thread, but if it does turn out to be unreliable, go get a glock or Springfield xd. They are extremely reliable and priced reasonably.
    Hope you figure it out.
  7. Dec 29, 2011 at 5:20 AM
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    You fell right into that one.
  8. Dec 29, 2011 at 5:36 AM
    wilki
    wilki Member
    florida
    2011 regular cab 2.7 2wd
    I do not own a DB380 but i work for a dealer that his sold quite a few of them. The good thing is that they are made in Cocoa Fl, so if there is a defect you can take it there and not have to ship it back. The first series (za serial numbers) db380 had problems. The current zc & zd serial number series have had updates and are running much better. The small 380 all can be a little ammo sensitive. This is even more the case during the first 200 rounds. I have no idea what your experience with handguns is so please dont take anything i say wrong. I suggest that you field strip the pistol and give it a good cleaning. This removes the factory lube which is normally more biased to rust prevention than lubrication. Re-lube liberally with a good gunoil like CLP or Rem-oil. Dont drown it but use more than you would normally. Get a box or two of a premium fmj like speer or federal. Winchester white box/USA is not very good for this as it is weaker and very dirty. Go back to the range and try again. When you shoot focus on your grip. It must be as firm as possible. Any wiggle or movement in your grip is bleeding off energy that is needed to cycle the pistol. Lock your elbows also. It should run better as you get thru those first few rounds and springs start to loosen up and the action smooths out. If it still chokes i would have someone else try it to rule out the shooter. Once it loosens up you will be able to shoot the cheaper ammo thru it. For what its worth i dont exspect any of the mini 380's to be the kind of pistol you can shoot 100's of rounds at a wack and not have a few hiccups. If your problems continue call diamondback. I know a problem with a new firearm can be very frustrating but if you call them try not to take it out on the person that answers the phone. Just explain the problem and ask them to help you and i am sure they will bend over backwards to make you happy.
  9. Dec 29, 2011 at 5:46 AM
    CaliforniaKid
    Jim
    Central California
    I appologize for my earlier response, it was rude and insensitive, and I have had the training. What Wilki said X2. I'll go sit in the corner now.
  10. Dec 29, 2011 at 8:00 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Thanks for responses my apologize for asshat response to first guys post. Anytime I ever post something on here I get dicks who comment or people who try being dicks but fail to even answer question. I assumed you were doing that so I was a asshat.
  11. Dec 29, 2011 at 8:03 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    I've read that winchester white box works good in them just haven't had chance to try yet. That's why I was curious if anyone else had one and experienced or corrected issues thanks for response
  12. Dec 29, 2011 at 8:24 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Yea My brother said untill I've put 300-500 rounds through it don't sell it or shelf it. . Like I said I was just curious if anyone else owns one and how well it's performed for them. Thank you for response though.
  13. Dec 29, 2011 at 8:33 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Thanks for response sir. By no means am I a expert shooter so I could have some effect but my moms boyfriend encountered same problems and he's a x-armed forces so hopefully not just me. I'll definetly give your advise a shot. Haha get it
  14. Dec 29, 2011 at 8:33 AM
    Hayes
    Brandon
    Denver, CO
    Here is why I posted what I posted. This is not a gun forum, you had 24 hours with no response, and the odds of someone having the same gun on here are slim.
    In your first post, you answered your own question when you said that you've read people have problems with cheap ammo. That's why I suggested that you try better ammo, since you've read the gun is picky.
    I'm sorry you thought I was being a dick, not my intention. The Internet is a funny place. I was telling you what I thought you should do, but you don't have to take my advice.
  15. Dec 29, 2011 at 8:35 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    My apologies to all I was a dick first. Like I said I'm just so use to asshole responding I turned into one myself. Had the training?
  16. Dec 29, 2011 at 8:41 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Understand it's not a gun forum that's why it's in guns section. And only reason I bumped after 24hrs was after that long its so far down on recents that no one would see. By bumping it's back at top im in hopes someone will see who owns one or has experience with them will see.
    And in first post I didn't answer my own question. I provided as much info as I could to my situation then asked if others experienced same issue. Dosent sound like I answered my question to me. Again sorry I took post wrong way.
  17. Dec 29, 2011 at 10:09 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    "Anyone own one? If so what ammo do you use? Any FTE or FTF happening to you?"
    Just looked at it again and still don't think I answered own question
  18. Dec 29, 2011 at 5:29 PM
    CaliforniaKid
    Jim
    Central California
    Also make sure it's not one of the clips. I always get extra clips when I buy a new toy and have gotten bad ones. If after 300 plus rounds it still ftf, check that its not one specific clip giving you the problem. Mark the bottom of the clip and when it jams if it's always the same clip, fix it or chuck it.
  19. Dec 29, 2011 at 6:00 PM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Yea I have 2 and 1 did seam to perform better.
  20. Dec 29, 2011 at 7:15 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    huh?
