DiamondBack Covers | Modifications
Discussion in 'DiamondBack Covers' started by catastrofe, Jun 14, 2018.
  1. May 4, 2019 at 3:14 PM
    #261
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    Built and installed my rack system for my Diamondback and RTT . It's cross bars are made from 120 wall 1"x4" steel, uprights are 120 wall 1"x3" then plated inside and out with 3/16" 4"x4" plate , closed cell foam gaskets on the inside . The rack can be taken off and the plates flipped to the top to seal the cover when the rack is not in use . Yes it's over built but this way I can carry what ever I need to . I'm adding a bike mount for my fat tire electric bike . Yes the struts can still hold the lids open , but I'll make some prop rods for it too.
  2. May 6, 2019 at 9:13 AM
    #262
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Hey guys, I have a question and perhaps someone can help me with a solution. I bought a DB/SE and the C clamps keeps getting loose. Is there a solution to this issue? Today, one of the C clamps was completely on the bed floor and 2 others were loose.
  3. May 6, 2019 at 1:20 PM
    #263
    STrooper
    Jack
    NC
    No one has experienced this issue??
  4. May 6, 2019 at 1:22 PM
    #264
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    If you mean the attachments that go on the bed rail to hold down the cover, Diamondback recommends re-tightening them at 100 miles. You could also put some locktite on the bolts to help as well.
    I have an HD and when I went to re-tighten them at 100 miles, they were still rock solid. Granted I have not been off-roading ( YET ) but I check them when I move stuff in and out of the bed.
    Hope that helps.
  5. May 6, 2019 at 1:41 PM
    #265
    STrooper
    Jack
    NC
    Yeah, i also read that in the instruction to re-tighten the clamps at 100 miles. I also thought of adding a lock nut on the top to secure the clamps as well, but not sure if that would work...
  6. May 6, 2019 at 1:43 PM
    #266
    pop.tremuloides
    Colorado
    2019 TRD OR DCSB
    Unless there is some sort of "cross threading" issue you should be fine.
    Either way give them a call if you are still having issues...they are great folks to work with!
  7. May 6, 2019 at 2:23 PM
    #267
    STrooper
    Jack
    NC
    Thanks for the input, i'll keep an eye on it for this week and call them if necessary.
  8. May 6, 2019 at 2:52 PM
    #268
    BattlecryTaco
    BattlecryTaco Well-Known Member
    So Cal
    3rd Gen TRD Off Road DCSB
    Check out the previous posts on this topic here:
  9. May 9, 2019 at 9:52 AM
    #269
    Mighty Snowpants
    Mighty Snowpants Member
    Me
    Somewhere in this thread or forum I read about a person who was originally told by DB to torque the clamps to a value and it broke the clamp and stripped the threads which he then got instruction from DB that said ooops, torque value too high - cut back. I can't remember the actual values. I'll try searching for it to see if I can find the thread posts.
    As for the flat bar thing - I'm going to use that idea - thank you.
  10. May 9, 2019 at 10:02 AM
    #270
    Mighty Snowpants
    Me
    Found the post discussing Torque value on the clamps for the DB cover. According to the post - the original DB instructions said torque the clamp bolts to 50 lbs. This ended up breaking the clamps and stripping the threads. Turns out the instructions were wrong. it should have been 20 lbs. Big diff. Most people don't use a torque wrench and get to 20 lbs easy. I thought I read the post in this forum but it turns out the post is in a Raptor Forum - so I didn't put the link in here.
    Doug777 likes this.
  11. May 9, 2019 at 10:06 AM
    #271
    Mighty Snowpants
    Me
    I had the same issue. I have the HD. I'm exploring options to reinforce. I did a search for different clamps and did not find the type of match I was looking for. I also asked DB for diff clamps or solution and all I got back was: compress the rubber down even tighter and add thread lock.
  12. May 9, 2019 at 10:17 AM
    #272
    STrooper
    Jack
    NC
    I believe that the clamps should of been engineered a little better to have piece of mind. I would hate to checked them every so often to make sure they are tight enough.
  13. May 9, 2019 at 10:26 AM
    #273
    Mighty Snowpants
    Me
    I agree. I briefly toyed with the idea of coming up with my own design made out of steel with locking nuts but I don't have those skills (or money) but someone else might.... The key would be to design a universal clamp but that's hard since each truck bed rail config is different and I don't have access to all the different trucks/model years. I guess one could start with 1 or 2 common trucks and go from there.
    BTW also thought about using a heavy duty C-Clamp or heavy duty bridge clamp but the dimensions of those clamps don't fit right. So now I own a few heavy duty clamps.
  14. May 9, 2019 at 4:47 PM
    #274
    ChortlingPorg
    ChortlingPorg Well-Known Member
    PNW
    2019 Cement TRD Sport AC MT
    I was thinking of mounting something to the top of my DB. Anything besides some silicone washers? Is anyone putting some silicone caulk between things and the cover? My concerns are leaking, and growing things between the item to be mounted and the cover. I live in Seattle which is a prime location for growing fungus type stuff.
    Or am I just overthinking and I should just mount the thing?
    Thank you!
  15. May 9, 2019 at 6:15 PM
    #275
    hawaii_dave
    2017 trd pro
    I got some closed cell foam that had 2 sided tape on it that I used on my rack to keep the water out. got it from a goodyear rubber supply shop down here in Eugene . I'm sure there would be a similar place to buy some up there . Or check out Amazon they have it too .
    ChortlingPorg[QUOTED] likes this.
  16. May 13, 2019 at 8:13 AM
    #276
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    I think your diamondback is installed too loosely. I go offroad especially gravel, washes and no rattling
    Papadave418 and Doug777 like this.
  17. May 13, 2019 at 8:15 AM
    #277
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    You mean with the tire lying flat on the bed right? Yes it will fit
  18. May 13, 2019 at 8:16 AM
    #278
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    I have when i first installed my db. Dont be afraid to torque em down theyre not going to break. Havent had issues since
  19. May 13, 2019 at 8:22 AM
    #279
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Woah, really?? I mean I know the tire will fit on top but you’re still able to open the panel that has a tire on it?
  20. May 13, 2019 at 8:43 AM
    #280
    Nu2taco
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    Ahh on top of the diamondback.. No. even if you upgrade the struts to take the weight, the tire takes about 3/5 the length of the bed and the tire will hit the middle panel
