DiamondBack Covers | Modifications
Discussion in 'DiamondBack Covers' started by catastrofe, Jun 14, 2018.
  1. Oct 28, 2019 at 12:41 PM
    #461
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    I’ll check back with you. That’s exactly why I got them. Should help once we figure out (hopefully) the bracket issue.
    PzTank[QUOTED] likes this.
  2. Oct 28, 2019 at 12:57 PM
    #462
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Sounds good. Give me another week or so and I’ll be installing mine.
  3. Oct 28, 2019 at 5:40 PM
    #463
    ceo32312
    ceo32312 Active Member
    Charles
    2018 White Tacoma SR
    Just pulled the trigger on an SE for my 2018 SR!
    orion808 and BattlecryTaco like this.
  4. Oct 28, 2019 at 9:51 PM
    #464
    deadpocketss
    deadpocketss Dingus
    Colorado
    '24 Subaru Crosstrek Premium
    I do run PNL because I have a toolbox that I keep back there.
  5. Oct 29, 2019 at 4:17 AM
    #465
    ceo32312
    Charles
    Any recommendations upon install? Waterproofing...
  6. Oct 29, 2019 at 7:05 PM
    #466
    Burdturger
    Burdturger Well-Known Member
    I'm sure this has been asked but can what set up is recommended to install a RTT on the SE? I wasn't considering ever getting a Rtt when i ordered my DB a couple weeks ago otherwise would have just gone hd
  7. Oct 29, 2019 at 10:10 PM
    #467
    dripcoffee
    dripcoffee Well-Known Member
    TRD Off-Road
    There are crossbar options that clear tonneau covers. I'm only familiar with kbvoodoo's high rise cross bars.
    I believe other folks have drilled and mounted roof rack rails directly into the diamondback cover and mounted racks that way.
  8. Oct 31, 2019 at 10:16 AM
    #468
    ortho
    ortho Well-Known Member
    Install was easy and so far I’m liking my SE a lot. Drove it in the snow and rain and it looks like everything is dry except where there are the gaps in the front of the bed- what did folks fill those in with?! Odd design for sure.
  9. Oct 31, 2019 at 10:19 AM
    #469
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I haven't filled mine yet, but I plan on using black silicone sealant for those two gaps.
  10. Oct 31, 2019 at 10:29 AM
    #470
    kwill
    kwill Well-Known Member
    I jammed some of the leftover sticky-back weather stripping in the gaps.
  11. Oct 31, 2019 at 10:42 AM
    #471
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    Same as what i did bought similar material on Amazon and covered all the gaps
  12. Oct 31, 2019 at 10:46 AM
    #472
    ortho
    What’s the consensus on installing the bulkhead kit?
  13. Oct 31, 2019 at 11:42 AM
    #473
    kwill
    Why would you not do it? It is easy and helps seal out water and dust.
  14. Oct 31, 2019 at 11:45 AM
    #474
    ortho
    In my case, it hasn’t been 50 degrees and isn’t forecast above low 30s for at least another week... I think the directions recommended 24 hrs above 50 for the adhesive.
  15. Oct 31, 2019 at 12:14 PM
    #475
    kwill
    I would keep the weather stripping inside, heat the metal with a heat gun (or hair dryer) and slap it down. I don't think it is that critical.
  16. Oct 31, 2019 at 8:38 PM
    #476
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    I did not put the bulk head stripping in. I've never had a leak up there. I did have a leak near the center panel, but that's because they installed part of the striping wrong there at the hinge... fixed that.
    Biggest think would be dust coming through those vertical gaps. Black silicone caulk would be ideal.
    BattlecryTaco likes this.
  17. Nov 1, 2019 at 11:34 AM
    #477
    Mrseafoo
    Mrseafoo Well-Known Member
    I didn't put the weather strip on and now I can't find it. Looks like I'm taking a trip to Home Depot.
  18. Nov 4, 2019 at 7:59 AM
    #478
    OPSGUY501
    OPSGUY501 New Member
    Anyone try to fit an 05-20 cover on a 2016+?
  19. Nov 10, 2019 at 12:11 PM
    #479
    verynearlypure
    Ernest
    The Buckeye State
    Ok well after being very patient with everything I have come to the conclusion that there isn’t enough adjustability with the DB SE and non OEM bed rails regarding my truck.
    I was able to get a decent tight fit but closing the panels is nearly impossible with one person. Not only that but I had to take the striker brackets and mount them on opposite sides AND upside down just to get a decent compression on the weather stripping. This allows for easy adjustability however due to the angle of the striker bracket, the lock rod rubber is easily damaged when opened and closed.
    There is no organic way for me to properly mount this cover and have full functionality while not damaging anything.
    DB isn’t able to make any custom striker brackets either so I am sitting with 2 unusable DB covers until I figure something out. I’ll have to reach out to them again.
  20. Nov 10, 2019 at 3:54 PM
    #480
    Jgoldstone
    Jgoldstone Member
    Jonathan
    San Diego, CA
    2019 Cement TRD Off-road 4x4
    Diamondback Cover BFG KO2's 265/70r17
    What type of non oem bed rails do you have?
