DiamondBack Covers | Modifications
Discussion in 'DiamondBack Covers' started by catastrofe, Jun 14, 2018.
  1. Nov 2, 2020 at 10:23 AM
    #961
    AtomicRyan
    AtomicRyan Well-Known Member
    I've yet to install one on a tacoma (mine is on order), but I've installed three on GMC full-size pickups. The first one took me 40 minutes or so... The last one took me no more than 20 minutes and probably closer to 15...
    dwhite750[QUOTED] likes this.
  2. Nov 2, 2020 at 10:29 AM
    #962
    kwill
    kwill Well-Known Member
    First time--maybe 30 minutes, including unboxing it. Subsequent times--5 minutes off or on.
    dwhite750 likes this.
  3. Nov 2, 2020 at 10:39 AM
    #963
    Salokin315
    Salokin315 Well-Known Member
    Nick
    Las Vegas, NV
    2020 Cement Tacoma TRD OR
    I installed mine last night, and I think it took me about 1 - 1.5 hours. It would have been faster if I had another person helping me full time. After I essentially installed everything, I didn't like how loose it "locked" so I re-did the adjustment points by having my girlfriend sit on the panels while I adjusted them. Would have probably saved 20-30 minutes by having her help in the first place. And also aligning the panel before bolting it down would have been easier with 2 people
    Edit: I should note, most of my struggles was due to poor lighting in my garage. My flashlight died about 20 minutes in so my visibility was pretty bad
  4. Nov 2, 2020 at 11:33 AM
    #964
    dwhite750
    dwhite750 Active Member
    2017 Tacoma PRO
    When you say aligning, are you talking about squaring it up with the bed? any other problems, Im getting mine at the end of the week.
  5. Nov 2, 2020 at 11:35 AM
    #965
    dwhite750
    2017 Tacoma PRO
    Did you use something heavy at each corner to compress it for lock adjustment?
  6. Nov 2, 2020 at 11:41 AM
    #966
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I had similar experience installing by my self and needing help to close the lid completely to adjust the bars.
    Re tightening the mounting clamps and adjusting the locking bars again after the seals compress, is key. After the first 150 miles the need to adjust was noticeable.
  7. Nov 2, 2020 at 11:42 AM
    #967
    AtomicRyan
    Yes... I think that's key to keeping them water tight. Here's what I do:
    - Get both the cab and tailgate panels aligned
    - tighten down the center support
    - Put at least 100 pounds on the cab side panel and adjust the locking mechanism to be tight.
    - Do the same thing with the tailgate panel.
    - Don't touch the thing for 24 hours.
    After 24 hours, the weather stripping compresses and creates a seal... It will be difficult to close the panels for the first week or so, but it gets easier and afterwards you will have a very good seal. You might also need to readjust after a few weeks.
  8. Nov 2, 2020 at 1:07 PM
    #968
    Salokin315
    Nick
    Las Vegas, NV
    Yeah squaring it up to the bed. First time I tightened them down I realized I was off center, so I had to loosen the bolts reposition, and because of that I had to re-allign the locking rods because one of the sides on "unlock" wouldn't clear the aluminum guide thing. (Hopefully that all makes sense)
  9. Nov 2, 2020 at 1:15 PM
    #969
    PiryongS
    PiryongS Well-Known Member
    I ordered mine from Diamondback on 30 Oct. The estimated arrival date is 18 Dec. Yikes!!!
  10. Nov 2, 2020 at 1:30 PM
    #970
    Salokin315
    Nick
    Las Vegas, NV
    I ordered mine on Oct 15th, email said estimated ship date Dec 3rd, actually received it Oct 28th. Granted, I ordered mine from Diamondback Outlet, so it was already made, but yours may come earlier than they estimate
  11. Nov 2, 2020 at 4:05 PM
    #971
    kwill
    I used 40 lb. kettle bells to help install mine. You do need to re-tighten the center clamps a couple of times after installation.
  12. Nov 2, 2020 at 9:08 PM
    #972
    ksimms92
    ksimms92 Well-Known Member
    Kevin
    West of Chicago
    2020 Silver TRD OR DCLB 4X4
    Same boat here, at early Oct. lead time was about 45 days. But I lucked out and got one from the outlet store. I believe it shipped about 3-4 days after ordering.
  13. Nov 3, 2020 at 3:55 AM
    #973
    dwhite750
    2017 Tacoma PRO
    Anyone have a link to the best install video for the DB?
  14. Nov 3, 2020 at 4:24 AM
    #974
    MrRyan
    MrRyan Well-Known Member
    2013 Tacoma TRD Sport 4x4
    Has anyone ordered that drop-in tool bin with their diamondback? I'm looking at ordering the DB HD but the lead time on both right now is 45 days so I was curious if anyone thought it was a must-have or not.
  15. Nov 3, 2020 at 6:21 AM
    #975
    kwill
    I have the large one and wouldn't do without it.
  16. Nov 3, 2020 at 7:39 AM
    #976
    Salokin315
    Nick
    Las Vegas, NV
    I used this video https://youtu.be/JZH4NatyZ-s and had no issues apart from the issues I explained earlier about doing it solo.
    Yeah I got the shorter bin and I love it, haven't kitted it out yet but I can already tell I'm going to like having that extra storage in the back that's separate from the bed.
    MrRyan[QUOTED] likes this.
  17. Nov 3, 2020 at 7:49 AM
    #977
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
  18. Nov 3, 2020 at 9:33 AM
    #978
    MrRyan
    Alright, I scrolled through all 49 pages of this thread and I have a question for you DB HD owners. I want to know if there are any cab high racks that can be used on the diamondback cover. I have an 18-foot outrigger canoe that I paddle around and it needs to go over the cab of my truck. I'm not wanting to get a roof rack for it so I'm wondering if there is a cab high rack that will either lock into the stock Tacoma rail system or use the cleats on the cover.
  19. Nov 3, 2020 at 9:58 AM
    #979
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    As for cab height racks, I don't think there are any options that will bolt to the cleats directly (as of right now at least). As for bolting to the stock rail system, there are a couple brands that make something that goes around tonneau covers in general, like RCI and KB Voodoo. These brackets won't allow you to open your cover though, so keep that in mind.
  20. Nov 3, 2020 at 11:54 AM
    #980
    TomTD
    TomTD Well-Known Member
    2018 TRD Sport
    I use the Diamondback racks, they work fine for me. I can fully open the front and back flaps without them hitting each other. It took a little while to get used to the lower visibility via the rear view mirror but now I don't notice it.
    CttAznRanger likes this.
