Dick Cepek DC2's and 265/70/15? HELP!
Discussion in 'Wheels & Tires' started by 96greengoblin, Apr 26, 2011.
  1. Apr 26, 2011 at 7:57 PM
    96greengoblin
    96greengoblin [OP] Active Member
    Hayden
    Michigan
    96 Extended Cab 4x4
    Billy's on all 4 corners!
    Yes I searched and couldnt come up with anything concrete.
    SO, I've got 265/70/15 Toyo Open Country AT's on some pretty jank rims that were on the truck when I bought it. Looking at getting DC2 15x8's. First, there will be no issue with the tires fitting, correct? How about rubbing or offset issues on stock suspension? I've got 5100's all around to install yet, just havent had the time. They will be set at 1.75 if that makes a difference. Thanks!
  2. Apr 26, 2011 at 8:12 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    you will have more than enough room, stock size is 265/70/16. you are 265/70/15 which is an inch smaller in diameter. and when you lift 1.75? that isn't an option on 1st gen billys. but you will be fine.
  3. Apr 27, 2011 at 7:40 AM
    96greengoblin
    Hayden
    Michigan
    96 Extended Cab 4x4
    thanks, good to hear. im a little confused on what you said about the bilsteins. according to downsouthmotorsports, where i ordered from, i have a choice of 1.75 or 2.5. if thats not the case, what do the 2 "rings" on them represent in terms of lift for a first gen?
    also, the recommended size for the 15x8's is 235, will my 265's be ok or should i order the 15x10's, where the recommended is a 32" tire...
  4. Apr 27, 2011 at 7:50 AM
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    I have Dick Cepek DC2's 16x8 on 285 75 R16 tires and I only had do some minor trimming.. You shouldn't have a problem... I'll post pics as soon as it stops raining up here in Mass and I can wash the truck :D btw... very nice looking rim.. I have them mounted on some bfg at's.
  5. May 23, 2011 at 3:54 PM
    pdubya88
    pdubya88 Member
    05 tacoma 5 speed 2.7
    k&n air intake
    will the dc-2s 16x8 fit fine on my 05 taco?
  6. May 23, 2011 at 3:56 PM
    pdubya88
    pdubya88 Member
    k&n air intake
  7. May 23, 2011 at 4:19 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    96 and 2011 are two different trucks...
    to the OP, you should be fine with those wheels, and you may want to stick to a 15x8 as they are easier to resell should you decide to change up at a later time...
    the backspace on the 15s is 3.625" which will stick out just right on a 96 if running 265-70s...
    once lifted, you might like the look of a 265-75 in there...
  8. May 24, 2011 at 5:50 AM
    masshole taco
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    my bad didn't see the year of the truck... Enjoy the new wheels.. ;)
