Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Jan 19, 2017 at 9:01 PM
    #2401
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  2. Jan 20, 2017 at 7:11 AM
    #2402
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    ChadsPride likes this.
  3. Jan 20, 2017 at 7:17 AM
    #2403
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Ouch
  4. Jan 20, 2017 at 7:36 AM
    #2404
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Price will probably be $12 when Scott gets his parts installed.
  5. Jan 20, 2017 at 7:38 AM
    #2405
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Jan 20, 2017 at 7:44 AM
    #2406
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  7. Jan 22, 2017 at 7:54 PM
    #2407
    tinker_troy
    T R O Y
    WY/SD
    Found this....
    ... seemed appropriate.
  8. Jan 23, 2017 at 10:52 PM
    #2408
    scocar
    scocar [OP] Patron of the Farts
    After reading through the debacles involving replacement of OEM shackle bushings (even "new" ones like mine are a pain, let alone worn-out rusted ones), I kinda looked into what is out there as an alternative, and didn't find much. Well, anything. I started considering purchasing a set of new OEM shackles (only about $76 each :rolleyes:) that I could modify on my bench at my leisure in advance of lift day. Then I could resell my slightly used ones to someone else who really needs a set.
    But then I run across another tip from @Crom, who himself only stumbled across it after going through the pain of just finishing his modified OEM shackles.
    http://www.4xinnovations.com/05-15-Tacoma-HD-Replacement-Shackle_p_148.html
    This things look awesome. I believe they can be used on the OEM shackle hangers and am asking a few questions to verify:
    Hi. I have a few questions about your Toyota Tacoma 05-15 heavy duty leaf spring shackle, Part Number ATO5009.
    Q: Can it be used on the stock OEM shackle mounts as a direct replacement without a flip kit or any other modification?
    A: Yes
    Q: The description says the are greasable. Do they include a tapped zirc in both bushing housings? I don't see any in the pictures, so I'm not sure.
    A: The bushing barrel has a grease zirc on it, it is on the opposite side of the barrel from the camera in the pictures.
    Q: Will the spring side of the shackle accept an OME/Dakar (ARB SB108) leaf spring bushing with a tight fit?
    A: The shackle will fit any spring that fits the stock shackle, so any spring that is advertised to fit the Tacoma. We are running the Dakars with the Dakar bushing set on my truck.
    Q: Finally, the description says "price includes two shackles." So for $95, I get a pair of shackles, one shackle for each side of my truck, correct?
    A: Yes
    EDIT: I had another googling after this post and discovered the source of the odd part number. ATO - Armor Tech Offroad. Apparently 4x bought them.
    EDIT: updated with answers from Adam at 4xInnovations.
    MQQSE, Crom, Bentrodder and 4 others like this.
  9. Jan 24, 2017 at 3:57 AM
    #2409
    98tacoma27
    Ben
    Not Beech Creek
    Why would you want to put that beautiful piece of finely engineered eye candy on this monstrosity?
    Did it as the Gods intended. AND QUIT PUSSY FOOTING AROUND!!
    Sorry, did I type that out loud?
    scocar[OP], Pchop and ChadsPride like this.
  10. Jan 24, 2017 at 7:00 AM
    #2410
    scocar
    Isn't it it looooooooovely
    Isnt't it it beu-eautiful....
  11. Jan 24, 2017 at 7:01 AM
    #2411
    ChadsPride
    Seent this guy live. It was epic af
    scocar[QUOTED][OP] likes this.
  12. Jan 24, 2017 at 7:08 AM
    #2412
    scocar
    Really? He's awesome.
    My sister bought this album, yes ALBUM, with VINYL and NEEDLES and shit, in Nineteen Hundred and 76 when it came out. I was 10. I loved it. I was learning to play trumpet, and this was my favorite.
    https://www.youtube.com/watch?v=wXrkg_DweRs
    MQQSE likes this.
  13. Jan 24, 2017 at 7:10 AM
    #2413
    ChadsPride
    Nice!!! yeah, he plays MANY instruments at his live shows.
    His backup singerz were awesome too!!!
    They all called him "My King"
    Thought that was cool
  14. Jan 24, 2017 at 7:13 AM
    #2414
    scocar
  15. Jan 24, 2017 at 7:17 AM
    #2415
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    *saw
    ChadsPride[QUOTED] likes this.
  16. Jan 24, 2017 at 7:18 AM
    #2416
    scocar
    Shhh.
    He's from Texas.
    Oh wait, you're from Florida.
    Jesus.
    MQQSE, tinker_troy and ChadsPride like this.
  17. Jan 24, 2017 at 7:19 AM
    #2417
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    I live in FL, from your neck of the woods. Santa Cruz local.
    MQQSE, Silver02Taco and ChadsPride like this.
  18. Jan 24, 2017 at 7:20 AM
    #2418
    ChadsPride
    No.
    :fistbump:
    tinker_troy likes this.
  19. Jan 24, 2017 at 7:20 AM
    #2419
    scocar
    Nope nope nope you're from FL now. Which is like Cuba sprinkled with fossils.
    MQQSE, tinker_troy, Crom and 4 others like this.
  20. Jan 24, 2017 at 7:34 AM
    #2420
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    You may have seent him, but he didn't see you. :rimshot:
