Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Feb 9, 2017 at 4:20 AM
    #2581
    98tacoma27
    Ben
    Not Beech Creek
    This seems more appropriate
    Crom, scottalot, scocar[OP] and 4 others like this.
  2. Feb 9, 2017 at 4:21 AM
    #2582
    98tacoma27
    Ben
    Not Beech Creek
  3. Feb 9, 2017 at 11:18 AM
    #2583
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  4. Feb 9, 2017 at 11:21 AM
    #2584
    scocar
    scocar [OP] hypotenoper
    +1 DMB
    Crom, scottalot, MQQSE and 2 others like this.
  5. Feb 10, 2017 at 6:34 PM
    #2585
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  6. Feb 12, 2017 at 8:51 PM
    #2586
    tinker_troy
    T R O Y
    WY/SD
  7. Feb 12, 2017 at 9:04 PM
    #2587
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    The beets were picked in Mexico by bad hombres
    Shipped to China for pickling, then brought over on Libyan registered ships.
    scottalot, ChadsPride and MQQSE like this.
  8. Feb 13, 2017 at 2:21 AM
    #2588
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    If Sarah should actually be named US Ambassador to Canada, 'cuz nothing can surprise me anymore o_O; when she quits/gets fired ... you may keep her.
    ... You are welcome. :canada:
  9. Feb 21, 2017 at 9:44 AM
    #2589
    scocar
    Kings arrived. They (King) blew the custom spec on the rears. Not sure what happened there. :mad:
    Micah was immediately responsive and is currently working through the issue to get it corrected. They are sending a return label today. :)
    Good thing I have zero time to do shit on the truck anyway.
    #shippingandreceivingislife.
  10. Feb 21, 2017 at 9:45 AM
    #2590
    ChadsPride
    Sponsored by TacomaWorld.com
  11. Feb 21, 2017 at 9:47 AM
    #2591
    ChadsPride
  12. Feb 21, 2017 at 9:55 AM
    #2592
    scocar
  13. Feb 21, 2017 at 9:56 AM
    #2593
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  14. Feb 21, 2017 at 9:59 AM
    #2594
    ChadsPride
  15. Feb 21, 2017 at 10:07 AM
    #2595
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Womp womp.
  16. Feb 21, 2017 at 10:07 AM
    #2596
    ChadsPride
  17. Feb 21, 2017 at 10:10 AM
    #2597
    23Skidoo
    Paul
    meme
    Sad
    ChadsPride likes this.
  18. Feb 21, 2017 at 10:33 AM
    #2598
    scocar
  19. Feb 21, 2017 at 10:34 AM
    #2599
    ChadsPride
    :laughing:
  20. Feb 21, 2017 at 10:38 AM
    #2600
    scocar
    I wanted 28/17/11
    They said they could do 27/17/10. I sucked it up and said OK
    I got 28/19/9
    Now that we have their attention, they are doing a custom cylinder length (which is frankly what I expected form day 1). I asked them to revisit 28/17/11 while they are at it. Since the slide rules will be all warmed up.
