Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. May 11, 2017 at 9:40 PM
    #2961
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    If the Earth was flat, cats would have pushed everything off the edge by now.
  2. May 11, 2017 at 9:41 PM
    #2962
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    :rofl:
    ChadsPride and 23Skidoo[QUOTED] like this.
  3. May 12, 2017 at 7:42 AM
    #2963
    Old School
    Old School You are ignoring covfefe by this member.
  4. May 12, 2017 at 1:46 PM
    #2964
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  5. May 19, 2017 at 8:41 PM
    #2965
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Tw really should consider banning Selfies.
    ChadsPride likes this.
  6. May 19, 2017 at 8:48 PM
    #2966
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Try the other hand.
  7. May 19, 2017 at 11:21 PM
    #2967
    scocar
    scocar [OP] Patron of the Farts
    Brilliant!
  8. May 20, 2017 at 11:00 PM
    #2968
    tinker_troy
    T R O Y
    WY/SD
  9. May 21, 2017 at 11:35 AM
    #2969
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    OP, thread sucks ... that is all ... carry-on.
    :fistbump:
  10. May 23, 2017 at 11:09 AM
    #2970
    ChadsPride
    Sponsored by TacomaWorld.com
  11. May 23, 2017 at 1:18 PM
    #2971
    Old School
  12. May 25, 2017 at 7:26 AM
    #2972
    ChadsPride
  13. May 25, 2017 at 8:29 AM
    #2973
    cmack
    cmack Well-Known Member
    18 Burrito
    this thread really went downhill
    Old School and ChadsPride like this.
  14. May 25, 2017 at 8:32 AM
    #2974
    ChadsPride
  15. May 25, 2017 at 9:15 AM
    #2975
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    It's practically a trench...
  16. May 25, 2017 at 12:06 PM
    #2976
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Shit, another 6 weeks and we will be talking fucking Chinese.
  17. Jun 5, 2017 at 10:27 AM
    #2977
    scocar
    When life gives you lemons....(I mean when you get banned)
    This weekend I got more done on my truck than I have in months. (Ken, this is basically a repost, so feel free to roam about elsewhere during this post).
    Hold your breath.
    1. I changed the oil. Only 1400 miles over the 5k OIC. I have been flogging the truck to death between both houses and two sets of contractors and family medical emergencies in the bay area. I never go more than a couple hundred over at most.
    This is what it looks like at the tailpipe. Lots of storms, lots of washing filthy windows so my blind spots are ever so slightly less blind, and A LOT of sticking my foot down hard way often than I ever would usually. My decision points have been markedly leaning to the aggressive side of late.
    2. I finally installed the supercharger!
    2 (revised). I did the air pump filter mod! Yes! Inspired by you @DVexile. The hood was open, so it took about 10 minutes as the oil was draining.
    Actually, I am looking at my new commute and how much more I'll be spending on gas and thinking that when it comes down to it, I'll either buy a dedicated used commuter car or sell the SC. We still have a lot to figure out with our new routine, so no rush there.
    Now I just need to rotate my tires. I do the 5-tire every 5k, but simply could not get to it this time.
    Upside: I've unpacked enough shit to be able to get the truck completely inside one bay and I have found all my maintenance stuff and parts, so I can at least do some night work on some things.
    Too busy chasing down some significant irrigation leaks at the new house during my "free time" with daylight on the weekends.
    Some areas suffering from inadequate irrigation from low pressure, and I'm paying to send perfectly good water down the gutter in some difficult-to-determine places. I think I have about 15 irrigation zones. I look into a known issue, test run zones, and listen an observe, and generally find a couple other things each time. A second person with coms would reduce my effort on this considerably. But at least I'm getting a lot more exercise. Not enough to be a supermodel, though. Yet.
  18. Jun 5, 2017 at 10:30 AM
    #2978
    ChadsPride
    I really wish you wouldnt, just my opinion though.
  19. Jun 5, 2017 at 10:31 AM
    #2979
    scocar
    I wish I wouldn't either. Clearly I am in no rush to make a decision either way.
    MQQSE and ChadsPride[QUOTED] like this.
  20. Jun 5, 2017 at 10:32 AM
    #2980
    ChadsPride
    Right on man, I know how it goes.
    I vote 89 Corolla and let the truck and SC get acquainted
    T4RFTMFW and Nickel like this.
