Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Nov 12, 2018 at 1:02 PM
    #4761
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  2. Nov 12, 2018 at 1:22 PM
    #4762
    scocar
    scocar [OP] Patron of the Farts
  3. Nov 13, 2018 at 8:44 AM
    #4763
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  4. Nov 13, 2018 at 9:22 PM
    #4764
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  5. Nov 15, 2018 at 6:00 PM
    #4765
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Oh I get it.... this is why I thought of this thread when I saw that pic....
    Silver02Taco, Pchop and Drainbung like this.
  6. Nov 29, 2018 at 5:00 PM
    #4766
    tinker_troy
    T R O Y
    WY/SD
  7. Nov 29, 2018 at 7:42 PM
    #4767
    nDub
    Lead Free Gasoline
  8. Nov 29, 2018 at 10:21 PM
    #4768
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Depressing in here. Wonder how the boxes are aging? Do you turn them @scocar every once in a while in their shelf position?
    tinker_troy, Drainbung and ChadsPride like this.
  9. Nov 30, 2018 at 10:32 AM
    #4769
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Goddamn Greek tragedy in here is what it is.
    tinker_troy likes this.
  10. Dec 2, 2018 at 8:07 PM
    #4770
    nDub
    Lead Free Gasoline
    ETAV8R, ChadsPride and tinker_troy like this.
  11. Dec 3, 2018 at 7:06 AM
    #4771
    scocar
    I put new wipers on yesterday. They're pretty badass. And only 2 months on the shelf.
    ETAV8R, T4RFTMFW, tinker_troy and 2 others like this.
  12. Dec 3, 2018 at 7:07 AM
    #4772
    ChadsPride
    Sponsored by TacomaWorld.com
  13. Dec 3, 2018 at 8:06 AM
    #4773
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Now, if only it would rain.
  14. Dec 3, 2018 at 10:33 AM
    #4774
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Rain X? Those are the best in IMO.
  15. Dec 3, 2018 at 12:30 PM
    #4775
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Treating your windshield with RainX helps a lot too, though needs to be reapplied a few times per year. The water just beads up, versus making a film. Cleaning the smoke film off from the summer, fall, winter fires you've had nearby will improve how well the wipers do their job too,
    nDub likes this.
  16. Dec 3, 2018 at 8:30 PM
    #4776
    scocar
    Wow did not expect this much interest. I guess the whole forum has gotten pretty shitty of late.
    I've had the Bosch Icons before, and I thought they were the best I'd ever tried over the years, but the local store did no have the sizes I needed and I had zero time to dick around. And there is oddly little room for error on these 2nd gen blades and shields.
    We just got hammered the last couple weeks, right after the deadliest fires in the state's history. Hence why wipers moved to the front of the line. OEMs, 3 years. And note that. OEM, 3 years. Heard some other guys saying they were not only inexpensive for the inserts, but long lasting.
    I've tried those before and was underwhelmed. Same with the Goodyears.
    I went with Napa Exact Fits. They are virtually identical to the OEM metal wiper arms and blades in every regard, including exact length.
    PN 6-021-1 and 6-022
  17. Dec 4, 2018 at 4:17 PM
    #4777
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Feel like those are OEM, essentially.
    Might grab those for woman’s car.
    scocar[QUOTED][OP] likes this.
  18. Dec 4, 2018 at 4:19 PM
    #4778
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  19. Dec 4, 2018 at 4:59 PM
    #4779
    scocar
    They differ slightly on close inspection, like with my fucking reading glasses on, and you can see that the secondary arms have slightly different geometry (longer) than the OEMs.
    Drainbung likes this.
  20. Dec 4, 2018 at 5:02 PM
    #4780
    scocar
