Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Apr 12, 2019 at 1:55 PM
    #5121
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  2. Apr 12, 2019 at 1:57 PM
    #5122
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Why is this very nice 2nd gen build in the 3rd gen build section? Looks stellar OP
  3. Apr 12, 2019 at 2:22 PM
    #5123
    scocar
    scocar [OP] Patron of the Farts
  4. Apr 12, 2019 at 2:25 PM
    #5124
    BassAckwards
    Lol this truck is a 2nd gen right? not sure if i've completely lost my mind.. It is near the end of tax season, so that is a possibility. Please advise
    ChadsPride likes this.
  5. Apr 12, 2019 at 2:28 PM
    #5125
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    No, it's a Double Cab TRD.
    tinker_troy likes this.
  6. Apr 12, 2019 at 2:29 PM
    #5126
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    If you had a 3rd gen, everything would become less clear. Just spend some time in the third gen section, then look back at this thread, and you will find this thread is at home here.
    BassAckwards[QUOTED] likes this.
  7. Apr 12, 2019 at 2:30 PM
    #5127
    BassAckwards
    Lol.. its already unclear enough, wouldnt want to know what it'd be like with a 3rd gen:anonymous:
  8. Apr 12, 2019 at 2:43 PM
    #5128
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Lol I missed that, didn't back up enough to change interfering to influencing.
  9. Apr 12, 2019 at 2:45 PM
    #5129
    BassAckwards
    Ahhhh lol, this makes more sense. It's one of "those" threads that qualifies for the 3rd gen section
    DVexile likes this.
  10. Apr 12, 2019 at 2:50 PM
    #5130
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    'Qualifies' ? It's trying to set the bar high, to be shown as an example to aspire to; which is why it is a sticky. Sadly though, this section is not quite up to the challenge.
  11. Apr 12, 2019 at 3:13 PM
    #5131
    scocar
  12. Apr 12, 2019 at 3:35 PM
    #5132
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  13. Apr 12, 2019 at 4:21 PM
    #5133
    scocar
    I mean it's OBVIOUSLY a Land Cruiser build, right? What is so fucking hard about that?
    Drainbung and nDub[QUOTED] like this.
  14. Apr 12, 2019 at 4:35 PM
    #5134
    nDub
    Lead Free Gasoline
    Clearly.
  15. Apr 12, 2019 at 4:38 PM
    #5135
    nDub
    Lead Free Gasoline
    Still a fan of the unimog build. You should link it in your bio.
    tinker_troy and Drainbung like this.
  16. Apr 15, 2019 at 11:08 AM
    #5136
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Wait....wut?
    This isn't a minivan mod thread? :facepalm:
  17. Apr 15, 2019 at 11:30 AM
    #5137
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  18. Apr 16, 2019 at 2:10 PM
    #5138
    ChadsPride
    Sponsored by TacomaWorld.com
    Drainbung and tinker_troy like this.
  19. Apr 16, 2019 at 3:45 PM
    #5139
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  20. Apr 16, 2019 at 5:35 PM
    #5140
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
