Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Jun 14, 2019 at 6:35 AM
    #5221
    mk1jacob
    mk1jacob Active Member
    Jacob
    East TN
    Timberland Mica DCSB
    5100s, 885s, 285s
    Do you happen to have any more pictures of your fix for these little side flap seals? I've been experimenting to no avail and remembered you had done this.
    Maybe one of the tailgate open, just so i can see the actual shape of the rubber piece?
    scocar[QUOTED][OP], Crom and gordi like this.
  2. Jun 14, 2019 at 8:20 AM
    #5222
    scocar
    scocar [OP] Patron of the Farts
    I'm afraid I don't. Here's what I have. I basically traced the originals as best I could, then made them a lot taller so I could use 3M auto trim tape for a large contact area.
    Originals. Basically a rectangle, with the outer edge curved to the cap contour:
    Notice the amount of flat space above the original:
    Here you can see how I made them taller, and put them under the main door seal:
    This is the best head-on shot I have. Top portion is taller, and the bottom portion is lower, too, but I had to keep test fitting and closing the tailgate to make sure it didn't deform too much. Go larger, and keep trimming the bottom edge as needed. Hope this helps:
    23Skidoo, Crom and mk1jacob[QUOTED] like this.
  3. Jun 14, 2019 at 8:22 AM
    #5223
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    The hell? There’s an actual helpful build related post in here now. Mods, time to move this out of the 3rd gen builds...
    Soul Surfer, Crom, scocar[OP] and 4 others like this.
  4. Jun 14, 2019 at 8:26 AM
    #5224
    mk1jacob
    Jacob
    East TN
    5100s, 885s, 285s
    That'll work for me! Thanks for sharing! My originals went incognito (trashed) after getting the shell painted lol, I'll stop and get some thinner rubber sheets this afternoon and finish her up
    That must mean he likes me, huh? ;)
  5. Jun 14, 2019 at 2:25 PM
    #5225
    scocar
  6. Jun 14, 2019 at 2:25 PM
    #5226
    scocar
    Oh fuck this is still in 3rd gen?
    Does it matter?
    I just don't know anymore.
    Crom and Drainbung like this.
  7. Jun 14, 2019 at 10:08 PM
    #5227
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You are right where you should be, setting an example for 3rd gen to aspire to, or is it the other way around :notsure:
  8. Jun 14, 2019 at 11:57 PM
    #5228
    scocar
    VE7OSR[QUOTED] and Drainbung like this.
  9. Jun 15, 2019 at 7:12 AM
    #5229
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Nice. I’m a fan of haikus.
  10. Jun 15, 2019 at 8:45 AM
    #5230
    scocar
    Was it the rotating one that uses four D batteries?
  11. Jun 15, 2019 at 8:54 AM
    #5231
    scocar
    Ooooooohhhh! My turn!
    Rolling glory dreams
    Gathering a rich Kingdom
    Then dust and despair
    DVexile, VE7OSR and nDub[QUOTED] like this.
  12. Jun 15, 2019 at 9:29 AM
    #5232
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Posted at the entrance to 'The Shelves'
  13. Jun 15, 2019 at 9:35 AM
    #5233
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Maybe something like this?
  14. Jun 15, 2019 at 10:00 AM
    #5234
    scocar
    In Elvish script, I suppose.
    Um....yes, yes that's it. Totally what I meant!
  15. Jun 15, 2019 at 10:09 AM
    #5235
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    So you posted it at 2' off the ground.Nice, good to hear you are providing an inclusive work environment.
  16. Jun 15, 2019 at 10:24 AM
    #5236
    DVexile
    Ken
    ...wrought of ithildin that mirrors only starlight and moonlight...
    VE7OSR and scocar[QUOTED][OP] like this.
  17. Jun 15, 2019 at 10:52 AM
    #5237
    scocar
    VE7OSR likes this.
  18. Jun 15, 2019 at 5:19 PM
    #5238
    nDub
    Lead Free Gasoline
  19. Jul 2, 2019 at 8:12 AM
    #5239
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  20. Jul 2, 2019 at 8:46 AM
    #5240
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    ChadsPride likes this.
