Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Aug 6, 2019 at 1:57 PM
    #5421
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Yeah, that uninsulated garage is going to be a sauna to work in. Humidity provided by your sweat!
    Soul Surfer likes this.
  2. Aug 6, 2019 at 1:57 PM
    #5422
    scocar
    scocar [OP] Patron of the Farts
    The detached garage is not a concern. It has a single 20A circuit now, and other than what you see on the wall there, it has a single duplex outlet on the exterior on the same conduit run. I might have a subpanel installed and pull more power out there, or just wait for the dream build. The house is 1932 build, but it has a new 200A panel with plenty of empty breaker slots and GFCI to both bathrooms which were redone in the late 90s and like a year ago. There are a few rooms with original knob and tube (and no grounding obviously), but it looks like new in the attic and has not been covered by insulation. We'll upgrade all that eventually.
  3. Aug 6, 2019 at 2:03 PM
    #5423
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Anything you can can get done in a week I can get done in 6 months.
    GHOST SHIP, Soul Surfer and MQQSE like this.
  4. Aug 6, 2019 at 2:07 PM
    #5424
    scocar
    At least it has no ventilation, either. But I have one of these, and am accustomed to laboring in high heat, if unavoidable.
  5. Aug 6, 2019 at 2:08 PM
    #5425
    scocar
    Consider who you are talking to, and what thread this is.
    I'll see your 6 months and raise you a year.
  6. Aug 6, 2019 at 3:12 PM
    #5426
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Definitely gotta save those doors ... beautiful, by real man standards. We need Dances with Wood appraisal.
    Chris ... seems feasible, no?
    :rofl:
    God I've missed you.
    Attaboy!
  7. Aug 6, 2019 at 3:32 PM
    #5427
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    :notsure:
    MQQSE and 23Skidoo like this.
  8. Aug 6, 2019 at 3:36 PM
    #5428
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Pfft....
    ......FIFY
    Remember boys, Scotts motto......ANYTHING worth doing once, is worth getting shelved, then redoing twice.
    scocar[QUOTED][OP] likes this.
  9. Aug 6, 2019 at 5:35 PM
    #5429
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I like the doors
  10. Aug 6, 2019 at 6:05 PM
    #5430
    scocar
    No, the loft is not. The stuff that is up there now was mostly left behind by the PO and is lightweight stuff. The joists are few in number (4) and undersized for an unsupported 15-ft span. At least one is visibly sagging at center. When I was working on the electrical, I realized I could strum the front joist with my finger like a guitar string. The vertical straps from the joists to the rafters are flimsy scrap T&G likely tacked on by a previous owner and provide no structural function whatsoever, other than perhaps adding downward tension to the rafters to encourage the roof to sag. :thumbsup:
    If I can be bothered for the short term, I would strip off the straps, jack the joists to level, and sister them. Then I would likely add collar ties to the rafters above them, and then add 2x4 vertical straps to actually provide upward support to the collars because the load would be carried down to the top sills by the stronger sistered joists.
    But then I'd just be creating future scrap. :burp:
  11. Aug 6, 2019 at 6:08 PM
    #5431
    23Skidoo
    Paul
    meme
    You could always support the sagging joists with shelves.
    Jeppa63, DVexile, Soul Surfer and 3 others like this.
  12. Aug 6, 2019 at 6:11 PM
    #5432
    23Skidoo
    Paul
    meme
    At our rate of project completion we could put our minds together, turning back the hands of time, thus doing it right the first time.
  13. Aug 6, 2019 at 6:16 PM
    #5433
    scocar
    Me too, but they have some longitudinal cracks in the hinge-side stiles, various areas of mending straps and plates, and flimsy diagonal support cables that I'd replace with something like turnbuckles.
    They work OK, one drags a tad on the ground at center for a couple inches. But security is dodgy at best, as is weather resistance.
    Not sure would reuse them as primary vehicle doors. I lover the rails and wheels, but maybe the actual doors would be better off being attached to a larger framed door structure. But that would be heavy as hell.
    Or something like this:
    Let me know if you've got any bright ideas or have seen other creative solutions.
    Soul Surfer, Drainbung and MQQSE like this.
  14. Aug 6, 2019 at 6:22 PM
    #5434
    scocar
  15. Aug 6, 2019 at 6:59 PM
    #5435
    23Skidoo
    Paul
    meme
    I feel younger already.
  16. Aug 6, 2019 at 7:05 PM
    #5436
    OZ-T
    Peter North
    British Columbia
    Nuke it from orbit , it's the only way to be sure .
  17. Aug 6, 2019 at 7:06 PM
    #5437
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :hattip: How are you Sir?
  18. Aug 6, 2019 at 7:11 PM
    #5438
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    He prefers the organic method....so I suggested a mixture of radon and ricin. :notsure:
  19. Aug 6, 2019 at 7:13 PM
    #5439
    23Skidoo
    Paul
    meme
    He needs a heat-gun and domino joiner.
    scocar[OP] likes this.
  20. Aug 6, 2019 at 7:17 PM
    #5440
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
