Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Sep 23, 2019 at 4:33 PM
    #5601
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  2. Sep 23, 2019 at 4:36 PM
    #5602
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    motherfuckin scurvy
    Pchop, 23Skidoo, MQQSE and 1 other person like this.
  3. Sep 23, 2019 at 5:03 PM
    #5603
    nDub
    Lead Free Gasoline
    MQQSE and Drainbung like this.
  4. Sep 23, 2019 at 6:18 PM
    #5604
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Well dayum. :facepalm:
    23Skidoo likes this.
  5. Sep 23, 2019 at 6:25 PM
    #5605
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Then there's that little force we call gravity, but you know that would mean understanding science, and facts 'n stuff.
    Edit: Does this mean Rob in Alaska has to make his load plans a wee bit more or less nose heavy of CG depending on where the plane is flying to?
  6. Sep 23, 2019 at 6:35 PM
    #5606
    nDub
    Lead Free Gasoline
  7. Sep 23, 2019 at 6:41 PM
    #5607
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  8. Sep 23, 2019 at 7:05 PM
    #5608
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Yeah, what's up with that? Darwin bringing back what's old is new again?
    edit: as i'm munching down on a juicy, locally grown peach, with apples, plums in the fridge as well.
    tinker_troy and 23Skidoo[QUOTED] like this.
  9. Sep 23, 2019 at 7:10 PM
    #5609
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    If that's what it takes to learn, well, okay go ahead.
    nDub[QUOTED] likes this.
  10. Sep 23, 2019 at 7:12 PM
    #5610
    23Skidoo
    Paul
    meme
    If at first you don’t succeed, try again.
    VE7OSR[QUOTED] likes this.
  11. Sep 23, 2019 at 7:29 PM
    #5611
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    oh sure ... nose heavy south, tail heavy north...tricky part is east and west. That yaw/roll equation gets complicated. o_O
    Silver02Taco likes this.
  12. Sep 23, 2019 at 7:33 PM
    #5612
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    something tells me you don't send too much material in the WNW direction, unless it was releasable ordinance, and good thing you know science, and physics, and stuff, and can do maths.
  13. Sep 23, 2019 at 7:36 PM
    #5613
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "We" don't, but our neighbours on base have stacks of presents nobody wants to receive. ;)
  14. Sep 23, 2019 at 8:02 PM
    #5614
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    'cause they can't be re-gifted? well as long as they don't sit around too long before they 'gift' themselves. That wouldn't be good. Gotta keep the wrapping in excellent condition. Probably are all pre-addressed to.
    tinker_troy likes this.
  15. Sep 23, 2019 at 8:05 PM
    #5615
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    a lot of the early testing ('83 to '93) of some of the packaging occurred over Canuckistan; in BC flying along some of our river canyons.
  16. Sep 23, 2019 at 8:07 PM
    #5616
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Yep, some of the neighbours have :canada: patches too. :)
    EDIT: Linked neighbours.
  17. Sep 24, 2019 at 5:24 AM
    #5617
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    He can do maths cause he has a
    Silver02Taco and tinker_troy like this.
  18. Sep 24, 2019 at 6:33 AM
    #5618
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I do? :confused:
  19. Sep 24, 2019 at 6:50 AM
    #5619
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Probably not
  20. Sep 24, 2019 at 6:56 AM
    #5620
    scocar
    scocar [OP] Patron of the Farts
    *an
