Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Nov 27, 2019 at 2:24 PM
    #5721
    scocar
    scocar [OP] Patron of the Farts
    Silver02Taco likes this.
  2. Dec 20, 2019 at 10:31 AM
    #5722
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  3. Dec 20, 2019 at 12:01 PM
    #5723
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    nDub and Silver02Taco like this.
  4. Dec 20, 2019 at 12:17 PM
    #5724
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Seems appropriate given @scocar heritage.
  5. Dec 20, 2019 at 4:54 PM
    #5725
    nDub
    Lead Free Gasoline
    Silver02Taco and Drainbung like this.
  6. Dec 20, 2019 at 5:49 PM
    #5726
    nDub
    Lead Free Gasoline
    tinker_troy and Drainbung like this.
  7. Dec 23, 2019 at 12:06 AM
    #5727
    scocar
  8. Dec 23, 2019 at 5:22 PM
    #5728
    scocar
  9. Dec 31, 2019 at 3:24 PM
    #5729
    scocar
    Feeling more optimistic...by 10% off
    Drainbung and Soul Surfer like this.
  10. Jan 1, 2020 at 7:45 AM
    #5730
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    That will be a fine selection of symmetrical boxes. How many of them come with a glossy texture with pictures on the outside?
    DVexile and Drainbung like this.
  11. Jan 1, 2020 at 8:27 PM
    #5731
    scocar
    All the Rough Country ones. 4 Wheel parts said the could cut me a deal and install for only $7k.
    Drainbung likes this.
  12. Jan 1, 2020 at 11:12 PM
    #5732
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    For $7000 US I could drive down and install those for you, even show Ben how it's done.
  13. Jan 3, 2020 at 4:34 AM
    #5733
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Seems a bit steep
  14. Jan 3, 2020 at 8:46 AM
    #5734
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Probably deserved though if you are buying Rough Country and 4 Wheel parts.
    scocar[OP] likes this.
  15. Jan 22, 2020 at 10:15 AM
    #5735
    scocar
  16. Jan 22, 2020 at 11:14 AM
    #5736
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  17. Feb 3, 2020 at 2:13 PM
    #5737
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  18. Feb 3, 2020 at 2:27 PM
    #5738
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  19. Feb 6, 2020 at 4:08 PM
    #5739
    tinker_troy
    T R O Y
    WY/SD
  20. Feb 6, 2020 at 5:18 PM
    #5740
    scocar
    Fuk.
    Shity Memes thread is lokt.
    I hav neu chois
