Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. May 1, 2020 at 6:12 AM
    #6161
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    I'd heard "Montana farmer" but same difference. Replace "kilt" with "501 Levis" and it's still gold.
  2. May 1, 2020 at 6:30 AM
    #6162
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Man, why do you have to denegrate the good ol' 501's dude?
    Say wranglers or some shit that is more Broke Back Mountain, but don't do that to 501's!!!!
    FastEddy59 and Drainbung like this.
  3. May 1, 2020 at 6:35 AM
    #6163
    CaptAmerica
    Cap
    The best defense of wearing 501s is the ability to go commando. "You can't go commando in anything other than 501s, son. When your pecker meets that zipper that's called "lighting the devil's match."
  4. May 1, 2020 at 6:38 AM
    #6164
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    The only reason to wear 501s is to publicize if you're dressing left or dressing right, or if you're a grape smuggler.
    23Skidoo, Drainbung and CaptAmerica like this.
  5. May 1, 2020 at 8:30 AM
    #6165
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Sheep are smarter than that. You'll have to do that part as well.
    23Skidoo and Drainbung like this.
  6. May 1, 2020 at 12:08 PM
    #6166
    scocar
    scocar [OP] Patron of the Farts
    Although very curious, their instincts are still unclouded by reason.
  7. May 1, 2020 at 12:43 PM
    #6167
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  8. May 1, 2020 at 5:27 PM
    #6168
    scocar
    gud dayum
    First guess!
  9. May 1, 2020 at 5:33 PM
    #6169
    23Skidoo
    Paul
    meme
    I was looking for a gif of “The age of reason” from that movie, gave up and went with Robin.
    Drainbung and scocar[QUOTED][OP] like this.
  10. May 1, 2020 at 5:35 PM
    #6170
    scocar
    Is it time for me to publish an update of Gulliver's travels?
  11. May 1, 2020 at 5:54 PM
    #6171
    23Skidoo
    Paul
    meme
    Sounds reasonable.
    Drainbung likes this.
  12. May 1, 2020 at 6:24 PM
    #6172
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    "sounds reasonable" = Blasphemy in this thread. Ban thyself from this place, fortwith.
  13. May 1, 2020 at 6:33 PM
    #6173
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    For those of us who joined later that Nov 12 2009... yes pls
    Cuz you probably had 1k posts by then :)
  14. May 1, 2020 at 6:35 PM
    #6174
    23Skidoo
    Paul
    meme
    Reasonably sound deduction.
  15. May 1, 2020 at 6:50 PM
    #6175
    TeecoTaco
    SW Ontario
    Are you introducing Doppler?
    23Skidoo[QUOTED] likes this.
  16. May 1, 2020 at 7:04 PM
    #6176
    23Skidoo
    Paul
    meme
  17. May 1, 2020 at 7:08 PM
    #6177
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    VE7OSR, Drainbung and 23Skidoo like this.
  18. May 1, 2020 at 7:23 PM
    #6178
    nDub
    Lead Free Gasoline
  19. May 1, 2020 at 7:28 PM
    #6179
    nDub
    Lead Free Gasoline
    98tacoma27, Silver02Taco and Biscuits like this.
  20. May 1, 2020 at 9:22 PM
    #6180
    Biscuits
    If y'all like Maynard Keenan, listen:
