Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Sep 15, 2020 at 6:55 AM
    #6921
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  2. Sep 15, 2020 at 7:00 AM
    #6922
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Now where did leave my nuts? Yes, should pave over all that Burnt ground with fake grass. Doesn't need watering or raking. Problem solved, and jobs created.
    23Skidoo, TheCochese and CaptAmerica like this.
  3. Sep 15, 2020 at 12:43 PM
    #6923
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  4. Sep 15, 2020 at 1:50 PM
    #6924
    scocar
    scocar [OP] Patron of the Farts
    I just want to take a moment to thank all my subbers for helping me every morning have a successful and satisfying bowel movement.
    This morning's was particularity noteworthy. Best I can do to describe it:
  5. Sep 15, 2020 at 1:56 PM
    #6925
    scocar
    :notsure:
  6. Sep 15, 2020 at 3:40 PM
    #6926
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    A reverse caber toss?
  7. Sep 15, 2020 at 3:49 PM
    #6927
    23Skidoo
    Paul
    meme
    That’s a big stick to have stuck up your ass. :eek:
    ETAV8R, syswalla and Drainbung like this.
  8. Sep 15, 2020 at 4:52 PM
    #6928
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    No joke. Saw a guy knock himself out cold doing that. Log came right back at him.
    Drainbung likes this.
  9. Sep 15, 2020 at 5:22 PM
    #6929
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    I’m here for you homey. Fiber bro, your age....fiber.
  10. Sep 17, 2020 at 7:58 AM
    #6930
    23Skidoo
    Paul
    meme
  11. Sep 17, 2020 at 8:02 AM
    #6931
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    need a pen that says "You don't know where this pen has been. Put it back."
  12. Sep 17, 2020 at 8:06 AM
    #6932
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Can’t quite figure out what it’s gonna show when you tilt the pen. Is it the Cunt or the Face? Who knows, maybe you get both before the pen goes Click.
    23Skidoo[QUOTED] likes this.
  13. Sep 17, 2020 at 8:27 AM
    #6933
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I had one of those a few weeks ago, legit thought I was going to pull an Elvis.
  14. Sep 17, 2020 at 2:16 PM
    #6934
    scocar
    Did you get the Mr. Hanky dot above the shoreline, and then it tipped over into the pool dead straight, on the center line of the Primary Poop Chute?
    23Skidoo and Drainbung like this.
  15. Sep 17, 2020 at 2:26 PM
    #6935
    TheCochese
    I had to flush seven times just to break the ship up.
    Drainbung and 23Skidoo like this.
  16. Sep 17, 2020 at 2:27 PM
    #6936
    23Skidoo
    Paul
    meme
    Sounds like splash back material.
  17. Sep 17, 2020 at 2:27 PM
    #6937
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Definatly Scott's... look how he's sitting
  18. Sep 17, 2020 at 2:27 PM
    #6938
    23Skidoo
    Paul
    meme
    I keep a hockey stick next to the toilet.
  19. Sep 17, 2020 at 2:30 PM
    #6939
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Sure you haven't any Canuck in you?
  20. Sep 17, 2020 at 2:59 PM
    #6940
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    That's to break off the frozen pyramid tip in the winter before it tickles your balls, and it better not be my good hockey stick.
    Chiseled down old goalie stick are the best for that.
