Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Sep 17, 2020 at 8:11 PM
    #6961
    scocar
    scocar [OP] Patron of the Farts
    23Skidoo likes this.
  2. Sep 18, 2020 at 6:55 AM
    #6962
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    CaptAmerica and 23Skidoo[QUOTED] like this.
  3. Sep 18, 2020 at 7:00 AM
    #6963
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Pchop[QUOTED] likes this.
  4. Sep 18, 2020 at 7:49 AM
    #6964
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Culture? Is that what we are calling it? Oh wait, yes, forgot where I am there for a moment. Correct in this thread that would be considered culture. Let me get my tuxedo on.
  5. Sep 18, 2020 at 8:19 AM
    #6965
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Don't forget the clown shoes, only thing fitting for this thread.
  6. Sep 18, 2020 at 8:22 AM
    #6966
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I have small feet. That might make it look like I'm compensating. I should probably get me a 1 ton diesel pickup, raised 8" rolling on 22" rims with 50 series mud tires to go with the clown shoes.
    Silver02Taco likes this.
  7. Sep 18, 2020 at 8:24 AM
    #6967
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Dont forget the double stack exhaust coming up out of the bed and a tuner so you can roll coal. :thumbs:
    VE7OSR[QUOTED] likes this.
  8. Sep 18, 2020 at 8:25 AM
    #6968
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I was thinking more along the rockers so I can smoke out the convertibles in either lane beside me.
  9. Sep 18, 2020 at 8:32 AM
    #6969
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Even Dickier, thread approved.
  10. Sep 18, 2020 at 10:18 AM
    #6970
    23Skidoo
    Paul
    meme
  11. Sep 18, 2020 at 11:32 AM
    #6971
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Is that a Swatch?
    b_r_o, FastEddy59, 23Skidoo and 3 others like this.
  12. Sep 18, 2020 at 11:51 AM
    #6972
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Pchop, VE7OSR, 23Skidoo and 2 others like this.
  13. Sep 18, 2020 at 5:11 PM
    #6973
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Thought it was a Fitbit at first. Then I thought, Why?
  14. Sep 18, 2020 at 5:42 PM
    #6974
    scocar
  15. Sep 18, 2020 at 6:26 PM
    #6975
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    911, what's your emergency?
    Drainbung likes this.
  16. Sep 18, 2020 at 6:26 PM
    #6976
    scocar
    democracy
    23Skidoo, TheCochese and syswalla like this.
  17. Sep 18, 2020 at 6:30 PM
    #6977
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    What kind of 'unfuck it' crew do you need? Shall I call in professionals or will an armchair warrior suffice?
  18. Sep 18, 2020 at 6:32 PM
    #6978
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    So a demolition crew, then. Sent ya a plague, appears you just need a bit more patience for the effects to take hold.
  19. Sep 18, 2020 at 6:34 PM
    #6979
    scocar
    Or napalm. Coordinates inbound.
  20. Sep 18, 2020 at 6:36 PM
    #6980
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Ah yes, the "disinfectant" method.
