Dick's Dank Yank Wank Tank
Discussion in '2nd Gen. Builds (2005-2015)' started by scocar, Oct 11, 2015.
  1. Jul 1, 2016 at 9:24 PM
    #1021
    cmack
    cmack Well-Known Member
    18 Burrito
    Also came with black lugs and two sets of hub caps
    ChadsPride likes this.
  2. Jul 1, 2016 at 9:33 PM
    #1022
    scocar
    scocar [OP] Patron of the Farts
    You should make a build thread.
  3. Jul 1, 2016 at 9:51 PM
    #1023
    cmack
    18 Burrito
    I have one
  4. Jul 1, 2016 at 10:10 PM
    #1024
    scocar
  5. Jul 1, 2016 at 10:13 PM
    #1025
    cmack
    18 Burrito
    You must be druck.
  6. Jul 2, 2016 at 11:54 AM
    #1026
    cmack
    18 Burrito
  7. Jul 2, 2016 at 11:56 AM
    #1027
    ChadsPride
    Sponsored by TacomaWorld.com
  8. Jul 2, 2016 at 12:03 PM
    #1028
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Appliance White.
    The only more coma inducing color than thrashcan silver
    scocar[OP], SalmonTaco and MQQSE like this.
  9. Jul 2, 2016 at 12:15 PM
    #1029
    cmack
    18 Burrito
    ChadsPride[QUOTED] and MQQSE like this.
  10. Jul 2, 2016 at 12:17 PM
    #1030
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    :fistbump:
  11. Jul 2, 2016 at 12:21 PM
    #1031
    tinker_troy
    T R O Y
    WY/SD
    Short box?
  12. Jul 2, 2016 at 12:23 PM
    #1032
    ChadsPride
    Got some negative rake action? New wheels? New tires? New sliders?
  13. Jul 2, 2016 at 12:27 PM
    #1033
    cmack
    18 Burrito
    Unfortunately
    Yeah I need new leafs. Working on ordering dakars. Tires are a year old as are the sliders. Both have been well used and abused
    ChadsPride[QUOTED] likes this.
  14. Jul 2, 2016 at 12:28 PM
    #1034
    ChadsPride
    My leafs are frowning before two years of ownership could come about.
    Thinking of ordering Maxtracs in the near future....I've got 2 inch blocks for the time being, but I would really really really like to replace these shitty leafs before the snapple
    Soul Surfer likes this.
  15. Jul 2, 2016 at 12:57 PM
    #1035
    tinker_troy
    T R O Y
    WY/SD
    Well at least it looks good.
  16. Jul 2, 2016 at 1:13 PM
    #1036
    cmack
    18 Burrito
    Long box wouldn't fit in the garage unless I did access cab
  17. Jul 2, 2016 at 1:52 PM
    #1037
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Sharp looking Wheel!! Everything balance up good?
  18. Jul 2, 2016 at 1:53 PM
    #1038
    cmack
    18 Burrito
    So far so good. Thanks
  19. Jul 3, 2016 at 10:58 PM
    #1039
    scocar
    Updated build notes.
  20. Jul 4, 2016 at 9:23 PM
    #1040
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You seem to have acquired a parasite here. Hope it's a symbiotic relationship.
    scocar[OP] and ChadsPride like this.
