Did a little research on Hydrolock
Discussion in 'Off-Roading & Trails' started by Yoytoda, Dec 13, 2009.
  1. Dec 13, 2009 at 9:24 PM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I was recently talking to a buddy about hydro/hydralocking. After going offroading and seeing two vehicle die in large puddles i decided to do a little research. I was sceptical that the starter had enough strength to bend a rod or blow a head gasket. Im sharing what i have found.
    When off-roading through water the biggest fear we all have is hydro-lock.
    Hydrolock (short for either hydraulic lock or hydrostatic lock) is a condition of an internal combustion engine in which an incompressible liquid has been introduced into its cylinder(s), resulting in the immobilization of the engine's pistons. The liquid causing this malfunction is often water. Internal combustion engines must compress air to work efficiently and this works because gases can be compressed. Liquids do not compress so if a volume of liquid greater than the volume of the combustion chamber at its minimum (top of the piston's stroke) enters the combustion chamber then the piston cannot complete its travel. Either the engine must stop rotating or something must give. The result is often a bent connecting rod or sometimes a cracked cylinder head or block.
    True hydrolock causes damage as soon as the engine stops. When driving through water, if the engine ingests enough water it will instantaneously stop often causing a loud clunk. (bent rod/cracked block). The damage is from having an engine turning several thousand rpms and suddenly stopping because the fluid does not compress.
    In my research I have found that it is a common myth that trying to start a hydrolocked vehicle can cause damage. The damage is usually done by the engine suddenly stopping from non compressible fluid in the cylinder while running. The damage is done before trying to start the engine.
    From experience, I have seen vehicles hydraulically locked and attempting to start the vehicle has not damaged anything. A toyota celica came to my fathers shop and wouldn’t start. Just a loud click. After we tested the starter and starter solenoid we dug deeper and found the owner had put wayyyyyy too much oil in the vehicle causing hydraulic locking. We drained 5 qts of oil and checked the level and it was just over the full mark. The lady had been putting a quart of oil in the car everytime she got gas because her husband told her to check it at every fill up. She misunderstood. Then one day she got gas and put a qt of oil in the car and it wouldnt start, not even turn over. With countless tries to start the engine there was no internal damage. She has had no problems and is still driving the car after we drained the oil and emptied the oil from the cylinders.
    There is hope for a truck if there is only enough water to cause combustion to stop not hydraulic locking. The best way to tell is if the truck starts to die slowly… not instantly. The water causes the gas to not atomize and combust properly.
    Have your offroading buddy pull you out
    Remove the spark plugs and crank the engine over to blow out any water.
    If you luck out and can get the vehicle running again, go home and change the oil in case any water may have made it into the case.
    Scrat and CMScheid like this.
  2. Dec 13, 2009 at 9:30 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    21 Tacoma TRD Off-Road Dbl Cab 4x4
    4WP Factory Front Bumper w/Warn VR EVO 10-S Winch, AuxBeam 8-Switch Controller, Redarc Trailer Brake Controller, ARE CX-Evolve Cap, Bedrug Liner, Ditch Pod Lights, Aftermarket LED (OEM) Bed Lights, Console Vault
    Good info! I was wondering that myself, since it was my first time off roading like that and having those 2 guys pretty much eat it.
  3. Dec 13, 2009 at 9:50 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    haha like your avatar there MHS. looks like were from the same area.
  4. Dec 13, 2009 at 9:50 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    does pulling the plugs and cranking really work? any videos anywhere of that happening...to lazy to search youtube
  5. Dec 13, 2009 at 9:53 PM
    MHS2846bg8
    Nate
    Yeah, i'm from Coos bay..currently stationed down in SoCal right now. Gonna be up your way at the end of december though!
    I'm pretty sure it does...I think that jeep that had problems on that run today might have done that...i'm not sure though. Never stuck around to find out. But never had any first hand experience myself.
  6. Dec 13, 2009 at 10:04 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    nice small right up rolland. cool meeting u today!
  7. Dec 13, 2009 at 10:05 PM
    Yoytoda
    Roland
    completely stock
    it works. i did it on my old k5 once when i got too much water in the intake.
  8. Dec 15, 2009 at 8:41 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Chris4x4???
  9. Dec 15, 2009 at 8:49 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Pulling the plugs and cranking does work, It also shoots the water out FAST. Anyone who went on the run with us remember that red jeep? Hes a buddy of mine, he hydrolocked his motor when it was stock, so we towed it home, pull the plugs and cranked the motor over. It shot water out A LOT OF IT.
  10. Dec 15, 2009 at 8:53 PM
    08pretaco
    az
  11. Dec 15, 2009 at 9:04 PM
    Yoytoda
    Roland
    completely stock
    the big thing i was surprised about is that it has been proven that trying to start a hydrolocked car wont bend a rod or damage the engine. The starter is strong but not strong enough to break anything. The damage is actually caused by the engine running and the water locking it up hard.
    The best way is to take the plugs out and crank it, clean the plugs and it will start. change the oil too as water probably got in it.
  12. Dec 15, 2009 at 9:11 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Change the Oil twice, my buddy changed his oil after that, and we pulled the dip stick and it was still milky. drained it again and the oil was milky.
  13. Dec 16, 2009 at 4:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'll have to disagree with this....
    Damage may not necessarily be caused immediately upon hydrolocking.
    It's not a myth...... and I'll try to explain it like this:
    Imagine you have 6 cylinders. When attempting to start the engine (with starter), at some point - the spark plugs will fire on the cylinders in the upstroke. When those cylinders fire - it forces the other cylinders into their compression stroke. If there is any water in those cylinders while its' trying to compress the water, that's where the damage is caused. You can have water in only ONE cylinder to cause major damage - while all the other cylinders can fire up as normal....when that one cylinder reaches the compression stroke, the damage can be done. Atleast, that's how I understand it.
    And yes....removing air filter & getting as much water out of the intake as possible, removing all plugs from the cylinders. Spray WD40 in the cylinders (to help displace the water). Crank the engine over and watch the water come flying out in a myst spray. Keep cranking the engine over until the spray is clean. Spray more WD-40 in each cylinder. Put spark plugs back in and try to start. It's smoke like a chimney for a while.
    This also works if you roll your vehicle and you get oil in the cylinders.
  14. Dec 16, 2009 at 8:46 AM
    Yoytoda
    Roland
    completely stock
    That does make sense, why risk it whether its a myth or not. just pull the plugs and cross your fingers the damage didnt happen the first time the water locked the engine...
  15. Dec 16, 2009 at 9:03 AM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    thanx i'll keep that in mind!
  16. Dec 16, 2009 at 9:26 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I did the remove the spark plugs thing on our jet ski when it sank overnight on the beach (we take it out of the water now lol). It worked great and started right up with the same plugs. That is a two stroke though.
  17. Dec 16, 2009 at 12:10 PM
    BaysMtnTaco
    BaysMtnTaco IH8MUD
    East Tenn.
    01 Tacoma SR5 3RZ
    None...yet.
    Random question:
    Im assuming the deckplate mod INCREASES the chances of this. Has anyone had any problems out of the deckplate mod with water in your intake?
  18. Dec 16, 2009 at 12:12 PM
    BaysMtnTaco
    BaysMtnTaco IH8MUD
    East Tenn.
    01 Tacoma SR5 3RZ
    None...yet.
    Good thread BTW. and an even better write-up
    Subscribed
  19. Dec 16, 2009 at 12:26 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    You put the deckplate in before wet conditions. And if sealed properly it should not be a problem.
  20. Dec 16, 2009 at 12:45 PM
    Hambone805
    Hambone805 Well-Known Member
    Aaron
    San Diego, California
    2015 4x4 Tacoma TRD
    STOCK :(
    i have the deckplate mod and dont worry about water getting in. the deckplate hole is right in front of the headlight housing (on my 02) so i dont see how much if any water would get around it. the only thing that i could think of if you go through a super deep whole and submerge it but at that point your introuble already and should have a snorkle. i keep mine open during rain, and when i take it to the car wash and its still running. but afwrestler is right, if your worried about it just screw the deckplate in before wet conditions.
