did BHLM, woo! got a 1/4" piece of hay inside one. WTF?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sook, Jan 29, 2011.
  1. Jan 29, 2011 at 8:20 PM
    sook
    sook [OP] Well-Known Member
    Chandler, AZ
    08 Sport PreRunner SSM dbl cab sb
    Avid Offroad light bar, Steelcraft step bars, Extang Revolution tonno, TRD black chrome headlights, 09 LED tails, all window tint, OEM DTRL w/ GM shorty bulbs, tailgate hose clamp, fighter pilot with red cold-cathode, Pioneer AVH-4300BT
    Okay, how do I get a tiny loose piece of hay out of my headlight? I mean seriously, what a stupid problem. We were so careful doing it. Can't even fathom. I suppose I could stick the compressed air can in there through the headlight bulb hole and blast it into a corner or something but I'd rather get it out.
  2. Jan 29, 2011 at 8:24 PM
    LILFURR
    LILFURR Well-Known Member
    Mitch
    Chesapeake, VA
    2005 4.0l 6speed sr5
    6 inch fabtech, 3 inch body lift spidertrax wheel spacers, grillcraft insert with black grill, black trex3 eyelids, custom VT emblem(not mounted) courtesy metalmiller, custom VT shifter courtesy pope953, bhlm, tinted fogs
    could you pull the whole assembly off and try and shake it and get the peice to fall out through the hole where the bulb goes?
  3. Jan 29, 2011 at 8:47 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Take a picture of it for me so I can see it to help out.
    I taken straws with 3m heavy duty tape stuck to the end of it.
    You then just stick it in and get any hair, lint, debris, silicon out. It happens a lot and no matter how careful you are about it.
    It is open and when you close it, there is a chance something gets in.
  4. Jan 29, 2011 at 10:18 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Get the hay on the lense in front of the bulb, then just stick a shop vac hose to the bulb opening...I'd think it can pull it out if its not a real big piece.
  5. Jan 29, 2011 at 10:29 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Wad up a gum wrapper, drop it in the bottom of a pop bottle, and I want to see you 'suck' it out with a vaccuum cleaner. You can't tip it upside down. It won't work.
    Couldn't help but say something....
  6. Jan 29, 2011 at 10:29 PM
    chaotichoax
    chaotichoax Well-Known Member
    Jeff
    Howell, NJ
    '11 MGM DC/SB TRD Sport
    I like the tape on a straw method, either that or skinny long shaft tweezers if you can reach it that way...obviously both through the bulb port
  7. Jan 29, 2011 at 10:49 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Why cant he manuever the headlight? I dont think he reinstalled it yet. :shrug:
  8. Jan 30, 2011 at 7:09 AM
    sook
    Chandler, AZ
    yeah, it's already back on the truck. i think im going to try plugging in a shop vac into the bed and sucking with that at the same time blasting with a can of air. dunno. i dont know how i would get to it with the pupil part that sits over the headlight bulb. the piece is way over in front of the turn signal.
    if i have to take it off, so be it.
  9. Jan 30, 2011 at 8:48 AM
    sook
    Chandler, AZ
    i looked at it again in the daylight. couldn't even make it move with the can of air. static cling has a hold of it. between that in the driver side and the paint scuff marks in the passenger side from reassembling the headlight, im really bummed. it almost looks total awesome
  10. Jan 31, 2011 at 11:26 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Did you do your BHLM in a barn?
  11. Jan 31, 2011 at 11:37 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I was going to recommend rigging a flexible straw to a shop vac with duct tape but unfortunately if that piece of hay is stuck on the paint, any success vacuuming it out might leave an unpainted mark left by the hay.
  12. Jan 31, 2011 at 11:52 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    double-sided sticky tape on the end of coat hanger wire bent to reach the piece of hay.
    or a hungry goat with a long skinny tongue
  13. Jan 31, 2011 at 12:09 PM
    Bobcat
    Bobcat Well-Known Member
    Montana
    :rofl:nice!
    Only in :oldglory:
  14. Jan 31, 2011 at 12:10 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
  15. Jan 31, 2011 at 12:21 PM
    Namyo
    Namyo -
    :laughing: this...
