Did Big O Tires Damage My TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, May 30, 2012.
  1. May 30, 2012 at 5:29 PM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I recently got all 4 tires changed, I drove home, the next day my TPMS light came on. It's been kind of intermittently working. What caused this? I also have an Toyota extended warranty, will that cover the TPMS sensors if they just "went bad"?
  2. May 30, 2012 at 5:29 PM
    Large
    Large Red
    Take them back to where you had the tires installed. They more than likely messed something up.
  3. May 30, 2012 at 5:33 PM
    OhYeah
    OhYeah Well-Known Member
    so cal
    2006 DCSB
    Have you checked the spare tire pressure? Im not sure how, but the dealer mentioned its also monitored when my light came on. They filled it up and the light went away.
  4. May 30, 2012 at 6:08 PM
    jeremy_283
    Yup, I checked all the tire pressures including the spare. I reset the TPMS as well, same issue.
  5. May 30, 2012 at 6:09 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Is it lit constantly, or blinking? Did you reset it using the button under the steering column?
  6. May 30, 2012 at 8:22 PM
    jeremy_283
    It stays lit and I tried resetting it using the button under the steering column.
  7. May 30, 2012 at 8:34 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yeah they probably broke one. Pretty common unfortunately.
  8. May 30, 2012 at 8:43 PM
    TexasTacoma37
    The light wouod be flashing, not constantly lit, if one of them were broken.
  9. May 30, 2012 at 8:46 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Hmmm sounds like they mightve kept the sensors:eek:
  10. May 30, 2012 at 8:56 PM
    jeremy_283
    How do I go about this? Will they buy me new OEM sensors if they broke them?
  11. May 30, 2012 at 9:01 PM
    jeremy_283
    Also sometimes there is no light and at other times there is. Is TPMS covered under Toyota warranty?
  12. May 30, 2012 at 9:07 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    1. have you checked your tire pressure, including the spare?
    New tires will actually loose quiet a bit of air the first few weeks of ownership because there will be leaks as the bead sits and the side wall flexes and stretches. Set your pressure to 35PSI on COLD tires then press your reset button following the directions in your manual. (Don't forget to check the spare. 05-08 have a TPMS in the spare. 09+ don't.)
    2. If your TPMS is damaged, your light would be flashing
    3. Toyota won't cover it because it was damaged, not a malfunction
    4. Big O would likely have to pay for the damage and replacement, if they admit to it.
  13. May 30, 2012 at 9:24 PM
    jeremy_283
    Yup I've checked pressures and all. What does a steady on mean?
  14. May 30, 2012 at 9:25 PM
    jeremy_283
    Additionally, they used the slippery slime I think to slip the tires on is what it looked like. Could that excess gunk have caused it?
  15. May 30, 2012 at 9:54 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Steady on , if you are referring to the TPMS light, is once you start your truck, it will flash 2-3 times, then stay consistently on fully lit.
    I believe that the tire bead lube won't affect the TPMS. It never did when I worked as a tire buster.
  16. Jun 4, 2012 at 6:03 AM
    jeremy_283
    now the light is off. dangit :facepalm:
