Did ECM Tuning Save Your Relationship? (Attn: 6MT)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moon22, Dec 12, 2023.
  1. Dec 12, 2023 at 7:56 PM
    moon22
    moon22 [OP] :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I'd especially love to hear from MT guys since a lot of tune praise errs towards AT shifting improvements..but is a tune on the 3.5 the reason you still have your 3G? Is it that transformative? I really want it to be that simple, but I really, really struggle with the idea that the power curve is shifted that much. Especially when the occasional guy chimes in with, "didn't really notice a difference." And then there are the dyno charts fueling speculation...without any way of seeing any changes below 2500 or 3000 RPM or something like that, where it actually matters for my interests.
    I want to hear from the guys who were on the edge and tuned out of desperation to make it work...and it did. The tune is THE reason you still own it. Or, it didn't, you bailed, and just like to come here and complain..yeah, this is your moment; spill thy tea, broseph. I'm personally ready to bail. I like the truck, but I don't like/enjoy it enough to justify its cost, considering I'm not really loving how it drives. I want to think that, like about anything else on these, it can be fixed - it just sounds like a really tall order and I am skeptical.
  2. Dec 12, 2023 at 7:59 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you aren’t satisfied now a tune is unlikely to change that. You can’t change the fundamental characteristics of the engine and that’s just about all that’s left when you have manual and control the shift point logic that is the main downfall of the truck with an automatic.
    leduc4wd, AusBerg, pushgears and 3 others like this.
  3. Dec 12, 2023 at 8:06 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    My opinion on all of the tunes I’ve tried is that they all have a very sensitive throttle that really wants to go as soon as you hit the pedal. I find that behind the very sensitive throttle, the engine is not really all that much stronger. Maybe a little bit, but it’s not drastic. I suspect many folks are fooled by the throttle into thinking that the tune gave them “more power” because in a way, the truck becomes significantly more responsive since it’s ready to go a lot more eagerly. Obviously, the dynos show some improvement. I’m not saying there is NO improvement, but after a bit of
    time driving a tuned truck, especially on a manual, you can still very easily get it to lug really bad and not have any power. In reality, there is only so much the tuners can adjust.
    Where the tunes disappointed me is that there is still very little “power” or torque down low, tuned or not. You are still ultimately limited by the way Toyota set the truck up to interpret the pedal. 2nd gear still lugs like hell below 10 miles per hour.
    Ultimately I have found that a regear combined with premium fuel and stock tune is the perfected version of driving this truck for me personally. The tunes with the regear made the throttle way too annoying to control at low speed.
    I’d suggest you just find someone nearby to test out their tuned truck if you can and go from there. Obviously it will be harder to find a manual to test but there are probably some out there. Personally I felt the tunes are quirky and ultimately I feel like I have the same power on the stock tune, just with much more padded throttle. 93 octane certainly helps the stock tune not feel anemic as the tune learns and advances timing slowly over time.
  4. Dec 12, 2023 at 8:23 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Stock tune for my 18 has its issues for sure. But, really, it's the engine torque curve that makes a manual 3rd gen an 'interesting' drive. Wrong engine for the application IMO and you are not going to change it much with a tune. But, I still enjoy driving it and have taught my kids to drive it. So, it can't be THAT bad.
  5. Dec 12, 2023 at 8:30 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  6. Dec 12, 2023 at 8:31 PM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    MT
    You are your shift points
    Re gear
  7. Dec 12, 2023 at 8:31 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    My odometer just turned 100,000kms earlier today. I have no tune and don't know if I will ever get one. I understand that if I want to go faster I need to hang out in gear longer. This engine has some good power in it as long as you know where to find it. Being a manual truck, it definitely helps being able to pick your shift points.
  8. Dec 12, 2023 at 8:32 PM
    PrerunnerVsix
    PrerunnerVsix Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    I got the d3 tune on my 2nd gen 4.0 and it made a huge difference. I like it a lot.
    GilbertOz likes this.
  9. Dec 12, 2023 at 8:51 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Engine is fine, tranny was a bad choice for both at and mt
  10. Dec 12, 2023 at 9:51 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    Peak torque at 4600rpm for a production truck engine does not make for a good manual experience. Those are the facts. It is not the transmissions (either auto or MT) fault.
    auskip07 and moon22[OP] like this.
  11. Dec 13, 2023 at 4:15 AM
    moon22
    moon22 [OP] :-|
    '12 TRD OR ACLB 6MT
    Drawing the line at regear. Starts to turn in to, “The Tacoma is a great truck and the 3.5 engine is a fine motor, despite criticism. Just need to tune it..and add a supercharger..and do a hilux transmission swap..and regear the axles..and maybe a transfer case doubler, but that last one is getting pretty hardcore”
  12. Dec 13, 2023 at 4:29 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    yeah I agree. That sounds like the jeep guys.
    moon22[QUOTED][OP] and Chew like this.
  13. Dec 13, 2023 at 4:46 AM
    MrWrestlingII
    MrWrestlingII Well-Known Member
    The truck from the factory has 2 problems. No low end torque and an absolutely horseshit tune. The torque problem cannot be fixed, the tune problem can.
    AT here, and I would have sold my brand new truck within the 1st year if not for a tune. For me the tune was transformative.
    moon22[OP] likes this.
  14. Dec 13, 2023 at 6:22 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I drove my truck for a year and a half without a tune and wasn't happy with the 1/3 throttle or less dead pedal feeling but I was able to work around it with the manual. I bought a camper and my first towing experiences were pretty bad. I had to do something to try and get more torque between 2000 and 3000rpm. I got the OTT tune. It made a big difference for me in the 2000-3000rpm range, especially pulling the camper. I think these tuners will let you try it and if you don't like it they'll switch it back to stock at no cost.
    moon22[OP] and Old Man Tan 4x4 like this.
  15. Dec 13, 2023 at 6:32 AM
    Old Man Tan 4x4
    Old Man Tan 4x4 Well-Known Member
    North East
    2017 TRDOR DCSB 4x4
    AT here but, the tune fixed probably 70-75% of the issues I had with my truck shifting wise. Still has some gear hunting and awkward up and down shifts but for me it's fine. I don't race my truck nor did I build it with racing in mind. It's a daily driver truck that I built for light off roading and it does both well enough to keep. There are just fundamental issues with the power train that can't be fixed by software. Regear and tune, I think that would be pretty transformative...but a lot of $$$ for something that might not change your mind. Honestly OP made the right choice getting a MT. I'd say try a regear first.
    33yrsoftoys likes this.
  16. Dec 13, 2023 at 9:22 AM
    duckytw
    duckytw Well-Known Member
    The KDMAX with premium was pretty damn amazing and Id still get it if I really wanted the sporty feeling back. As of now, Im fine with the latest toyota tune, though still miss having a 7k-something redline.
  17. Dec 13, 2023 at 9:28 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    The day I realized that you need to get the revs above 3k to shift smoothly is the day I started having a better time driving the Tacoma.
    Unfortunately, with the way the engine makes power, you kind of need to drive it like a 4500lb Miata.
  18. Dec 13, 2023 at 9:32 AM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    But, but, but............ I want my problem to be somebody else's fault!
    :annoyed:
    Speedfreak[QUOTED] likes this.
  19. Dec 13, 2023 at 9:34 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    A long time ago I bought the full OVT VFTuner package and tune files. It made a world of difference and made it very "peaky" from the line so I had to get used to that. Average mileage went down a couple of MPG but fun factor went way up. I'm sure there are better tunes available now over the default VFTune but haven't had a reason to update it so far. I might see about buying a tune file or two from some of those tuner guys just to try them out but only if I can get them for $100 or less since I'll do the work myself and just need the file.
    TL;DR: yes, it makes a huge difference.
  20. Dec 13, 2023 at 9:35 AM
    Old Man Tan 4x4
    North East
    2017 TRDOR DCSB 4x4
    Agreed, give it more skinny pedal and let it sing. Quite fun to drive when you realize this.
