Did front brake job. Now won't brake evenly. PLEASE HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by 626TACO, Jul 28, 2013.
  1. Jul 28, 2013 at 3:34 PM
    626TACO
    626TACO [OP] Active Member
    SoCal
    01 PreRunner SR5 V6
    I just replaced the front rotors and pads because I had warped rotors. Now the brakes wont brake evenly. Right side starts smoking and also pulls to the right during heavy braking. Please help.
  2. Jul 28, 2013 at 6:48 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Needs bled right it sounds like.
    You need to bleed the brakes, both front ones and the rear one plus the rear proportioning valve
  3. Jul 28, 2013 at 6:52 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    air in the system not letting the one piston back when it gets hot. I agree, Bleed.
  4. Jul 28, 2013 at 7:22 PM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    If you bleed'em and you still have the same problem you most likely got a leak in your brake line or boot
