Did I buy to much for my lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by F1Fan, Jun 6, 2012.
  1. Jun 6, 2012 at 12:57 PM
    F1Fan
    F1Fan [OP] Member
    Scott
    Land o Lakes
    2012 Tacoma TRD Sport DCLB 4x4
    Toytec ultimate lift kit with Dakar rear leaf springs. 3"NFab's
    I have spent many hours on this site researching my lift. This is what I ended up ordering. Toytec ultimate lift with Dakars. I also added the diff drop kit, carrier bearing drop kit, axle shims and the sway bar relocate kit. What are yor thoughts? Did I miss anything? Didn't go with UCR yet as want to see if my shop can get it aligned without them first. Thanks for your input. I plan on pulling the boat out of the water before the lift to get some good before and after shots with weight on the back. Not sure if anyone would find that useful or not.
  2. Jun 6, 2012 at 1:50 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    if you are going full 3in you should get uca's
  3. Jun 6, 2012 at 2:05 PM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, DynaPro 265/75/16 ATMs, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    I just installed the Toytec Ultimate w/Dakars a couple of weeks ago along with Total Chaos UCAs.
    Did not install the diff drop, bearing drop, or shims. Figured I'd wait to see if they were needed. Absolutely no problems.
    Do the UCAs. When I had my truck aligned, the toe was the only item out of spec.
  4. Jun 6, 2012 at 4:23 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    the bigger benefit of the UCA's over the alignment help is the down travel you will get back. IMO 3" lift coilovers that max out the stock UCA is really only half the lift kit.
  5. Jun 6, 2012 at 11:54 PM
    DevL
    DevL Well-Known Member
    Axle relocate plate or longer bumpstops to keep larger tires from contacting front of rear wheel well under full compression. Cab mount chop plates up front.
  6. Jun 7, 2012 at 12:05 AM
    BeeRadd
    BeeRadd ANTI-DARK Vendor
    Brad
    Fountain Valley, CA
    2008 DCLB 4x4 TRD Sport
    Mag light mod, ABS Kill switch, On board air, tail-gate theft mod, Redline hood struts, Shovel mount, Rubberized undercoated frame, CB radio w/lil wil magnet antenna, LED interior light, Shocker 228 Train horns, black valence, fog lights anytime, black hood scoop, eyelids, anti-seatbelt chime hack, weathertechs,
    SUB'd. Good info on here
  7. Jun 7, 2012 at 6:21 AM
    F1Fan
    F1Fan [OP] Member
    Scott
    Land o Lakes
    Thanks for all the advice. My rim and tire set up will be the 16x8 Ivan Stewarts with 265x70x16. Do you think the cab mount chop plates and the axel relocate plate would still be necessary?
  8. Jun 7, 2012 at 6:25 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    No, that's a stock tire size.
  9. Jun 7, 2012 at 6:51 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    You won't need to chop the cab mount unless your running 285's. Only thing I install with my 3" OME lift was the CB drop. No vibes at all. I did install the LR UCA's though. Truck aligned perfect.
