Did i cook my transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Avex, Jul 28, 2019.
  1. Jul 28, 2019 at 9:46 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Next time use 4LO. I have an ultragauge and from wheeling in the mountains I have noticed the tranny heats up 10x faster in 4HI when going up steep grades. There is just a ton more slippage happening in the torque converter. Adding a couple thousand pounds of weight only exacerbates things.
    Alexely999 likes this.
  2. Jul 28, 2019 at 10:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup. 4lo would of aleviated OP putting the trans into overheat limp mode for sure.... 2.56x easier on the trans due to gear reduction.
    Sounds like op was going very slow up a steep road with a good amount of load... 2HI or 4HI this will heat up the trans fluid even with the tow package VERY quickly, even in first gear.
    My suggestion to OP. While the fluid might look fine, for peace of mind, spend the 100-120 bucks on new Toyota WS fluid and replace it, while your at it pop in another trans cooler with an inline thermostat, then next time when you have to tackle that hill, also use 4LO!
    Avex[OP] and Alexely999 like this.
  3. Jul 29, 2019 at 7:56 AM
    Avex
    Avex [OP] Well-Known Member
    Alex
    PNW
    Thanks everyone, going to replace transmission fluid, already ordered the derale cooler and installed the scan gauge that I had sitting around. Appreciate the help
  4. Jul 29, 2019 at 8:13 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    BTW you can use another AT Fluid that is compatible with our Tacoma ATs. Many including myself have used Valvoline Maxlife with good results. I would recommend a full flush. I know resident transmission guru gearcruncher doesn't think very highly of Toyota WS transmission fluid.
    PzTank likes this.
