Did I damage something internally when replacing my ABS sensor?
Discussion in 'Technical Chat' started by fifteentango, Oct 13, 2023.
  1. Oct 22, 2023 at 6:27 PM
    #61
    fifteentango
    fifteentango [OP] Well-Known Member
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    3" Old Man Emu suspension lift, 3" body lift, 33" tires
    I'm sorry, I just realized how dumb I was being. It's 11.74V at the connector.
    Metric Rider likes this.
  2. Oct 22, 2023 at 6:33 PM
    #62
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Ok so we have battery voltage on it at both ends correct?
  3. Oct 22, 2023 at 6:43 PM
    #63
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    No. It's always 2.3mV at the ECU and battery voltage at the connector.
  4. Oct 22, 2023 at 6:48 PM
    #64
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You sure your on the right pin at the ECU?
    This is the one you should be on.
  5. Oct 22, 2023 at 6:51 PM
    #65
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    ….I thought that was B26. The worksheet calls it B2 which also happens to be green. Let me go look at that one.
    Metric Rider and Dm93[QUOTED] like this.
  6. Oct 22, 2023 at 6:52 PM
    #66
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    I just realized that the dude made a typo when he made up the little sheet to record everything….
    Metric Rider and Dm93 like this.
  7. Oct 22, 2023 at 6:55 PM
    #67
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    Alright, I measure the correct pin, it's 11.74V at the ECU also.
  8. Oct 22, 2023 at 7:03 PM
    #68
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    :anonymous:That was me, ugh srry about that:frusty:
    @TnShooter where were you at on that one:rofl:
    I'll get it corrected as soon as I eat.
    Ok what is it with the ADD plugged in? Again I'm srry for all this I tried my best to check my work for typos but I guess that one slipped through.
  9. Oct 22, 2023 at 7:07 PM
    #69
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    :anonymous: If I didn’t catch it in almost 2 years. I would never had caught it.
    Well, not until my 4WD system messed up. :eek:
  10. Oct 22, 2023 at 7:09 PM
    #70
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I had it right in the original chart but I screwed up when I made the printout chart:annoyed:
  11. Oct 22, 2023 at 7:10 PM
    #71
    TnShooter
    Deogee
    STOCK
    If there’s anything I’ve learned from this whole thread.
    OP is persistent and has a lot of patience and determination.
    I can’t say the same about me. :rofl:
    Metric Rider, Williston and Dm93 like this.
  12. Oct 22, 2023 at 7:14 PM
    #72
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    Thanks TnShooter. I just want my damn 4WD to work. I live 2 miles above sea level in the mountains of Colorado and it's about to be snowing.
  13. Oct 22, 2023 at 7:15 PM
    #73
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    Hey man, it's still great work and has helped me be a bit organized with all this.
    BTW, I tested the ADD at the ECU with it connected and it also read 11.74V
  14. Oct 22, 2023 at 7:27 PM
    #74
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Almost everything in these beloved trucks are in an inconvenient spot. Just saying you're not alone in this thinking. Hang in there!
    Metric Rider, TnShooter and Dm93 like this.
  15. Oct 22, 2023 at 7:37 PM
    #75
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok the chart is fixed.
    So the ADD is unlocked but it's either between positions or something is not right since DL1 and DL2 are at 0v
    The Transfer Case Actuator also looks like it may be between positions based on TL1 and TL2 being 0v
    I think pop the transfer case actuator cover off and rotate it as far counterclockwise as it will go and see if your contacts line up with the 2H position.
    Metric Rider and TnShooter like this.
  16. Oct 22, 2023 at 7:40 PM
    #76
    TnShooter
    Deogee
    STOCK
    I was literally sitting here looking at the shift sequence chart to see if I could figure out “where” it’s stuck. :rofl:
    I have to keep telling myself
    Open = 12v
    Closes = 0v
  17. Oct 22, 2023 at 7:46 PM
    #77
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I use the pictures with the contact positions marked to determine where the actuator may be based on the voltages.
  18. Oct 22, 2023 at 7:53 PM
    #78
    TnShooter
    Deogee
    STOCK
    So far, if I’m reading the shift sequence right.
    We’re stuck between 2H and 4H on the transfer case.
    TL2 is closed, but TL1 never opens.
    4WD position never closes either.
    OP, none of this matters as it doesn’t help “fill the issue.
    But it gives us an idea where we are “stuck”.
  19. Oct 22, 2023 at 8:38 PM
    #79
    fifteentango
    Brandon
    Leadville, Colorado
    2007 TRD Off-Road
    Ok. I really dig the foresight though. I have to be up at 4:30 for work tomorrow, but I’ll be home around 4pm mountain time. Should I start messing around with the transfer case actuator? If so, what exactly do I need to try?
  20. Oct 22, 2023 at 9:32 PM
    #80
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    See my post above, I think the next step is to pop the cover off the Transfer Case Actuator.
