Did I F@$& up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaineTaco, Sep 19, 2009.
  1. Sep 19, 2009 at 1:58 PM
    MaineTaco
    MaineTaco [OP] The NUTS
    Bangor, Maine
    06 AC 4X4 4.0 6speed Base
    K&N drop in, Ride TSB, Tail gate TSB, Scan Gauge ll, Factory seat covers, Hella head lights
    Guys, I just changed my Oil and after filling up with Moble-1 full Syn, I went to replace the Oil cap and noticed that it said 5w-30. I just put in 5 bottles of 5w-20, so will I be ok if I leave it the way it is or should I change it out for 5w-30? This was completely I F-up and I should know better, but what should I do now? Thank you in advance!
    Will
  2. Sep 19, 2009 at 2:00 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    You're ok, but if it were me, I'd drain it and change to 5W-30.....but I know how expensive it is to waste.
  3. Sep 19, 2009 at 2:02 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Yeah you should drain it, it happens.
  4. Sep 19, 2009 at 2:07 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    I would leave in there. We are at the end of September and the temperatures are not as hot. Do a search and find out what all these numbers meant. You are OK.
    Leave it alone.
    take care,
    vbibi:(
    Ps. Lets give the right advise.....
  5. Sep 19, 2009 at 2:10 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd flush it. Even though it's not cheap to replace the oil, it will be a whole lot more expensive to have something go wrong and be replaced. It will be hard telling Toyota that you put 5W-20 in there and expect them to replace what went wrong when the manual calls for 5W-30.
  6. Sep 19, 2009 at 2:11 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
  7. Sep 19, 2009 at 2:21 PM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    if it were me, I'd drain half of the 5w20 out and add M1 0w40. Save the drained 5w20 for your next change and mix it again with 0w40.
    btw, the M1 0w40 is an excellent oil, one of the best that mobil makes outside of their racing stuff. It mixes fine with thinner viscosities.
  8. Sep 19, 2009 at 2:28 PM
    crawl
    Greg
    Valencia, CA
    colder climates use 5w or 0w. the second number represents viscosity at operating temps, which is independent of outside temperature. the 5w20 is much thinner once heated than 5w30. At 100*c, the vis. is 8.8 vs. 11.3, which IS significant.
  9. Sep 19, 2009 at 2:35 PM
    K5423
    K5423 Well-Known Member
    Mesa,AZ.
    2010 Tacoma Double cab V6 SR5 TRD Offroad
    K&N air filter
    My dealer put 5W20 in my 2010 Taco that I bought new a month ago.They put a sticker on the top right inside of my windshield stating this.
  10. Sep 19, 2009 at 2:36 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Exactly. Leave it.
  11. Sep 19, 2009 at 2:45 PM
    crawl
    Greg
    Valencia, CA
    ^^^where are you guys getting your info. from??? the motor reaches the SAME operating temperature, whether 0* or 100* outside.
  12. Sep 19, 2009 at 2:48 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    no biggie i used to run 0w-30 amsoil in my 07 prerunner..
  13. Sep 19, 2009 at 2:54 PM
    crawl
    Greg
    Valencia, CA
    thats still a 30 weight oil when heated, which is fine. plus Amsoil is a different animal all together.
  14. Sep 19, 2009 at 3:03 PM
    TacoTRD420
    TacoTRD420 ( . Y . ) = :)
    Jake
    Kaplan,La.
    2011 FJ T.T.
    Toyota FJ TT...Pretty much stock.
    i run 10w-30
  15. Sep 19, 2009 at 3:05 PM
    MaineTaco
    Bangor, Maine
    Hey guys thanks for the help! I will drain it and put in the right stuff, just to be on the safe side. I am lucky, because my wife’s van (2006 Dodge Grand Caravan 3.8 V6) uses 5W-20 so it won’t be wasted. Thank you to all that replied, you guys are a great group to be involved with.
    Will
  16. Sep 19, 2009 at 3:09 PM
    K5423
    Mesa,AZ.
    K&N air filter
    Your just wasting your time draining it.You have nothing to be afraid of.Your to paranoid.Your truck will be fine.
  17. Sep 19, 2009 at 3:12 PM
    MaineTaco
    Bangor, Maine
    Well I just want to play it safe with a $25,000.00 truck, and like I stated the oil will still be put to good use. Thank you for your input anyhow.
    Will
  18. Sep 19, 2009 at 3:12 PM
    Incognito
    VA
    No problem Will!
    Good decision to be safe. ;)
    Better be safe than sorry.
  19. Sep 19, 2009 at 4:01 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
  20. Sep 19, 2009 at 4:34 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Not with a modern thermostat and cooling system. Especially in the instance that electric fans are used.
    Achieving operating temperature takes a longer period of time, although the final operating temperature (coolant) and oil temperature are nearly identical under like driving conditions. There is although an exception, sub-zero temperatures would be them.
    If you are running a fully synthetic oil, accidentally using 0-30 instead of 5-30 would not be an issue, although there is a significant difference in viscosity from a 30 weight to a 20 weight oil.
