Did I get a Lemon?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smta, Jul 20, 2022.
  1. Jul 23, 2022 at 6:46 PM
    #441
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    In MA it can take 18 months or more to settled a Lemon Law claim. It's not just a matter of filling a claim and the AG waves her magic wand. Claimants often have to hire an attorney and go through mediation.
    I haven't read the entire thread and don't plan to. 23 pages in three days is ridiculous.
    OP hope it works out for you, but somehow I don't think it will.
    There are a lot of Toyota stores in MA. Find one that is interested in fixing your truck. If they make you happy, they'll end up making more money on service than the original dealer did selling it to you.
    soundman98 likes this.
  2. Jul 23, 2022 at 10:22 PM
    #442
    22TCLB
    22TCLB Well-Known Member
    Tim
    2022 tacoma lb
    Same here in Ca. A co worker took a year and a half to lemon law his wife's car. Had to hire a lawyer. Seems like the buy back case turned into a pissing contest at the end.
    HisDad[QUOTED] likes this.
  3. Jul 24, 2022 at 5:22 AM
    #443
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Bought my truck in boston ma....very happy with it. No lemon law needed here.
    I'm not familar with the lemon law in ma., but here in connecticut you have 2 years or 24k miles to claim it from the new vehicle purchase date. The manufacture gets multiple tries to repair the issue, before considering it to be a lemon. Only then your entitled to get your money back, or another vehicle.
  4. Jul 24, 2022 at 5:28 AM
    #444
    zoo truck
    None
    I didn't realize that, assumed it was the 3.5. In that case you have a legitimate beef. Like already said..its in warranty. Stop worrying. Either way it'll all work out.
  5. Jul 24, 2022 at 2:12 PM
    #445
    Skytek
    Skytek Well-Known Member
    Damn. Out of boredom just read through this entire thread. Of course curious about what the problem was but too dumb to skip to the end to see that nothing happened. It’s been said more than once, but jeeze,
    Make a service appointment. In the meantime drive it like you stole it. It’s under warranty. Get complaints documented at service. If no problem has been found, continue driving until a problem arises. If this happens after warranty period, you will have discovered there is no gravity, the world just sucks. To hell with the safety concerns of driving as is. You have to accept some level of risk anytime you leave your driveway. Where a helmet if it makes you feel better.
    Sucks to expect perfection and not get it these days, especially with the cost of vehicles, but that’s the way it is these days. Seems the op was really bothered that a problem occurred unexpectedly. I suggest he buy a gm. No suprises there, your gonna have problems
  6. Jul 26, 2022 at 9:00 AM
    #446
    TheBeerBladderMonster
    TheBeerBladderMonster Active Member
    2021 4x4 Toyota Tacoma SR Access Cab
    Tonneau Cover and Side Rails
    In all honesty and just my opinion it sounds normal to me at 1300 miles.
    You've barely broke it in. I suspect after your first oil change and few more hundred miles this sound will lower itself.
    Signed- a 2021 2.7L owner that heard the same thing with mine. I'm now at 12,000 miles no issues.
    tstack22 likes this.
  7. Jul 29, 2022 at 8:27 AM
    #447
    Pauul_90
    Pauul_90 Member
    Paul
    2017 toyota
    I just got the same issue yesterday once I left orientation truck has 106767 mi its used. Has oil. Is this a rod bearing does anyone know if you can replace bearings without pulling motor???
  8. Jul 29, 2022 at 9:43 AM
    #448
    zoo truck
    None
    That would be unusual. I've the the 2.7 many times over the years, none have made a knocking, or clattering noise. If it were this 3.5 we have today, yeah, at 1,300 miles it'd be perfectly normal.
  9. Jul 29, 2022 at 9:51 AM
    #449
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Well, at some point I thought the OP said that the noise doesn't speed up with engine revs. If that is the case, it's likely not an internal engine thing. Could be an odd harmonic vibration from the fuel pump or something.
  10. Jul 29, 2022 at 2:18 PM
    #450
    Skytek
    You could gain access to rod bearing by dropping oil pan. But if it’s bad enough your hearing it, likely needs more than a rod bearing. To replace rod, you would need to pull head and bring piston and rod out the top. At that point i would pull it and consider exchanging for a rebuilt if your not equipped to overhaul it.
    But as previously mentioned, if the op reported noise doesn’t change frequency with engine speed, can’t imagine it would be internal engine components. I did have a buddy with a timing chain tensioner failing in a Honda that made a noise that didn’t exactly follow engine speed. Who knows, shouldn’t be that hard to figure out. A cheap stethoscope from harbor freight would probably identify it
  11. Jul 29, 2022 at 3:22 PM
    #451
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I could be many things
    Why assume it’s the bottom 1/2 of the motor ? It needs to be properly diagnosed before you can assume anything .
  12. Jul 29, 2022 at 3:24 PM
    #452
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Ok, what’s the status? Dealer fixed your issue?
  13. Jul 30, 2022 at 2:27 PM
    #453
    Pauul_90
    Pauul_90 Member
    Paul
    2017 toyota
    My taco is a 3.5 v6 4x4 trd sport I only put around 50k miles on it I'm 2nd owner should it be making that sound at 106k mi
  14. Jul 30, 2022 at 9:26 PM
    #454
    22TCLB
    Tim
    2022 tacoma lb
    Yeah, what happened to the OP? Update.
  15. Jul 30, 2022 at 9:27 PM
    #455
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    He got a lemon so he made lemonade.
    CrispyTacoLover likes this.
  16. Jul 30, 2022 at 9:31 PM
    #456
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Troll
  17. Jul 31, 2022 at 6:52 AM
    #457
    perterra
    perterra Well-Known Member
    Tejas
    His parents grounded him.
  18. Jul 31, 2022 at 9:46 AM
    #458
    TruckGuy63
    Gilbert
    New York
    The funny part about this whole thread is that all of this is just an assumption until it’s correctly diagnosed. I remember a long time ago I bought a Plymouth Duster with a 360 4 speed manual. It was a beautiful car at the time . Black with a white racing strip buckets etc , which was rare for those cars back then . When I bought it in 1979 it was 5 years old and had 19k miles. The engine ran good and good power but had what I thought and the owner thought to be a nasty valve or lifter tap. So because of that I bought the car as is for 750 dollars. ( keep in mind brand new the car was $4500 brand new.
    I was 16 at the time so I went for it . When I got it home I asked a bunch of different people there opinions on what the noise was and everyone was saying I needed head work to cam lifters and timing chain, and all this craziness . The noise kept getting louder and because I was a kid with basically ont to much money I pulled the air cleaner off and started looking around and I noticed in the the back of the motor one f the bolts holding the exhaust manifold was partially out. It was literally finger loose . As a matter of fact they were all loose . Long story short I took them out added lock tight retorqued them and guess what , the engine was quiet as can be and never made a sound again . I never forgot that. Until I know for sure I don’t make any assumptions.
  19. Aug 1, 2022 at 5:48 AM
    #459
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    FYI. If a motor has true rod knock, its only a mater of a few miles before the motor will completely let go.
    True Rod knock is NOT one of those noises you can just have for a while. You wont be able to drive hundreds/thousands of miles with it.
  20. Aug 1, 2022 at 6:05 AM
    #460
    zoo truck
    None
    The knock might be related to those timing chains/tensioners....at least what an auto repair garage friend told me.
