Did I get any water into my differential??
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBlitz, May 10, 2011.
  1. May 10, 2011 at 12:57 AM
    TacoBlitz
    TacoBlitz [OP] Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    Went offroading a few weeks ago and ran into some trouble but still had a blast.
    I do not have a diff. breather extender and I am wondering how easy it really is to actually suck water into the differential and looking to see some people opinions on whether or not I may have caused any problems from my recent encounter with water and mud. Thanks
  2. May 10, 2011 at 1:11 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    That looks like alot of fun...
    I would just change the fluid to be on the safe side...its easy and will cause you less headache and $$$ in the long run
  3. May 10, 2011 at 1:12 AM
    TacoBlitz
    Jake
    Omaha, Nebraska
    that is probably a good idea, thanks
  4. May 10, 2011 at 1:17 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    Have you done the rear diff breather mod?
  5. May 10, 2011 at 1:23 AM
    TacoBlitz
    Jake
    Omaha, Nebraska
    nope
  6. May 10, 2011 at 1:26 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  7. May 10, 2011 at 9:09 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Where is that spot in Omaha Ne. Papio Creek!
  8. May 10, 2011 at 9:11 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I bet that cleanup was fun...
  9. May 10, 2011 at 9:19 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You can check for water without completely draining it. Just slowly unscrew the drain plug until it starts leaking. Milky oil, it's got water. Plain water,:eek:, drain, flush, and refill.
    Make sure you crack the fill plug before you mess with the drain plug!
  10. May 10, 2011 at 10:33 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Also, if you've never opened your rear dif, listen for a 'gasp' if you have pressure built up and exiting when you unskrew either the fill cap or the stock breather, then your breather wasn't working right in the first place. Do the breather mod - I just did mine. Worth the 30 minutes and 5$ so you don't trash 30$+ worth of oil every other weekend :) (nice pics btw)
  11. May 11, 2011 at 8:27 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I've been stuck 50 times, and 100 times worse. You'll be fine :)
  12. May 11, 2011 at 11:15 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    I got water in myn somehow with the diff breather mod, if the oil is foamy/grey you'v got some in there
  13. May 13, 2011 at 12:48 PM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    Did you run yours to your gas door? That portion doesn't make any sense to me as water does get in there during heavy rains... so why you would route the hose there doesn't make sense. i'm thinking i'll go somewhere in the wheel well that's out of waters reach, but havent had much time to re-route yet.
  14. May 13, 2011 at 1:44 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Milky is the operative word here. Foam is another problem entirely.
    As the diff spins it mixes in air. Old oil or hard running will cause this. The air should settle out quickly.
    Milky oil is caused by the water being emulsified in the oil. That's the oil doing its job. It keeps the water away from the metal. Over time (or too much water) the water will separate. The viscosity also decreases. Water, emulsified or not, will cause rust, or burn out bearings because of poor lubrication. Excessive air will cause the same problems, but it is a separate problem.
    Some people run the breather to the cubby over the wheel well. It is protected from hard rain and higher than the rear storage cubby(which might get flooded by a creek crossing).
  15. May 13, 2011 at 11:09 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar Toyo Open Country AT/3's Bilstein 5100's up front, (#2) & 4600 in rear Daily driver....
  16. May 15, 2011 at 12:00 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Thanks for all the good info everyone, I will definitely follow your advice
  17. May 15, 2011 at 12:03 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    thanks lol, I nearly sacrificed my camera to get them but it was worth it.
  18. May 15, 2011 at 12:09 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    I spent about 8 hours on it and it is still not completely back to the way it was.. my interior got murdered. not to mention how rusty everything underneath got. STILL well worth it though, can't wait to do it again, I don't plan on getting stuck that badly though
  19. May 15, 2011 at 12:14 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    It was actually in iowa right by the Missouri river
