Did I just f**k up my ride rite bags?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lipripr, Sep 10, 2013.
  1. Sep 10, 2013 at 8:11 PM
    lipripr
    lipripr [OP] Active Member
    Colorado
    2006 TRD 4x4
    I just installed some ride rite suspension bags last week (thanks to this forum for the help) and today I had my truck up on a lift to change all the diff fluids and the bags were stretched out !!!! Now I'm losing about a pound of pressure in around 5-6 hours. It looked like the bags were the only thing holding the axel to the frame it didn't look good at all. Any help or experience would be appreciated. Thanks
  2. Sep 10, 2013 at 8:20 PM
    tennisbum132
    tennisbum132 Well-Known Member
    Texas
    2013 Tacoma TRD Sport 4x4 DCLB
    Full LED upgrade from csjumper2003, Andre's Devil Horns Emblem, Coupe's TRD Battery Tie-down, WeatherTech Digital Fit Liners, Scangauge II, Trailer Harness Relocation Bracket, Snugtop Rebel Cap
    I hate to say but I agree with Beavis. I worked for Discount Tire Co. for quite some time and every time we had a vehicle come in with air bags installed factory or otherwise we had to turn off the bags to prevent damage. We didn't catch them all and in the process ended up having to pay to replace more than we should have. Hope that isn't the case but it is definitely a possibility. Goodluck!
  3. Sep 10, 2013 at 8:35 PM
    lipripr
    Colorado
    2006 TRD 4x4
    Thanks for the replies.
    Haven't had a chance to check all connections and the bags. Will tomorrow.
    What is meant by turning them off? Just emptying them of all their air? They only had around 8 psi when it went up on the lift.
    Can trucks with ride rites never go up on a lift or do you have to support the axel some how? Sorry for all the ?'s I've only had them on for a week and I'm freakin out a bit. Was happy with the install and how they worked for a week.
  4. Sep 10, 2013 at 8:41 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  5. Sep 10, 2013 at 8:57 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    8 psi shouldn't tear them. I would be leaning more towards a fitting some where. Maybe a length of hose got a little over extended, or a smalll hole from rubbing on something.
  6. Sep 10, 2013 at 9:03 PM
    lipripr
    Colorado
    2006 TRD 4x4
    Thanks bt I'm going to go over everything very closely tomorrow after I get back from grouse hunting/elk unit scouting. (my buddy's 2013 tacoma pulling my king quad) I hope you're right. Thnx.
  7. Sep 10, 2013 at 9:07 PM
    acdronin
    acdronin Well-Known Member
    Yeah soapy water spray on them, maybe pump them up a bunch so you might spot a leak easier.
  8. Sep 11, 2013 at 3:45 AM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    Agreed. I've put the bags on two different trucks and they both experienced leaking a few weeks after install. Both times fittings were found loose, tightened up and all was well.
    David
  9. Sep 11, 2013 at 3:48 AM
    kb2tha
    kb2tha Well-Known Member
    Delaware County, NYS
    08 SR5 TRD OffRoad
    Scangauge
    Keep us posted with an update please. I just ordered a used set for my TRD OR access cab.
  10. Sep 11, 2013 at 5:00 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    If I'm not mistaken the instructions direct you to vent the bags completely before lifting.
    For future reference, if you install the Daystar Cradles ( here: http://www.daystarweb.com/productdetail.php?productID=1232 ) you don't have to worry about lifting since the bottom of the bag is detached from the axle and riding in the cradle.
  11. Sep 11, 2013 at 7:06 AM
    fla taco
    fla taco Well-Known Member
    Central Florida
    05 Dblcab TRD OR
    sub'd. Installed ride rites a few weeks ago and love 'em. Please post your findings....Good Luck!!!
  12. Sep 11, 2013 at 10:28 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    You can damage air bags by letting them hang like that. Not saying it did but it could. Make sure to drain them down before lifting. Also check all your fitting as said before. Possibly just a loose connection somewhere.
  13. Nov 5, 2013 at 8:15 PM
    larolco
    larolco Member
    Vancouver, BC
    2006 SR5 sold 2023 SR5
    So what was the finding here? Bags damaged? Leak elsewhere? This thread's not nearly as useful without a verdict.
  14. Nov 5, 2013 at 10:28 PM
    acdronin
    yeah man, I feel totally ya know deflated man, sucks to be just be.....wait for it.......left hangin!
  15. Nov 7, 2013 at 8:23 PM
    larolco
    larolco Member
    Vancouver, BC
    Seriously. I wanna know.
    A guy posts for help and all, gets it, and never reports back. Jeez.
    If I have to wait for it, I want something legend.....wait for it....airy.
  16. Nov 7, 2013 at 9:28 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Double check your connections. Sometimes they can be a little tough to get right. You have to press real hard sometimes. Also remove the valve stems and put back in and refill. Mine sometimes leak from the valve stems.
    But yeah per the instructions you need to removed all the air before you lift the truck. I just remove the valve stem before it goes in and i have a portable compressor to refill after.
