Did I lift too high?!? Can it be saved??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by loaderman82, May 11, 2018.
  1. May 11, 2018 at 7:50 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Yep those CV boots are gonna be hurting.
    tcjacado and oni06 like this.
  2. May 11, 2018 at 7:51 PM
    loaderman82
    loaderman82 [OP] Well-Known Member
    Dalton
    Flippin, AR
    2008 Off-Road
    So take out the spacers and drop it down one notch?
    tcjacado likes this.
  3. May 11, 2018 at 7:52 PM
    tcjacado
    tcjacado Well-Known Member
    :eek:
    oni06 likes this.
  4. May 11, 2018 at 7:53 PM
    tcjacado
    Yes
    Slashaar and Prayn4surf like this.
  5. May 11, 2018 at 7:53 PM
    TacoTuesday94
    TacoTuesday94 Well-Known Member
    Ry
    Huntington Beach CA
    Supercharged 4.0 2010
  6. May 11, 2018 at 7:54 PM
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    Will I be able to fit my tires?
  7. May 11, 2018 at 7:55 PM
    tcjacado
    What tire was it again?
  8. May 11, 2018 at 7:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    See post 17
    stickyTaco likes this.
  9. May 11, 2018 at 7:56 PM
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    305/65-17. I also have 1 1/4 spacers if needed. Method nv 17 x 8.5 wheels with 0 offset
  10. May 11, 2018 at 7:57 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Also pick up some silicone lubricant for the cv boots it will help them last longer. the aftermarket uca ie total chaos or camburg etc helps the coils travel correctly and will solve your problem with the coils rubbing. Maxing the coilovers like what was said is not recommended
  11. May 11, 2018 at 7:57 PM
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    I’m ok with cutting
  12. May 11, 2018 at 7:57 PM
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    :bananadead:
  13. May 11, 2018 at 7:59 PM
    Prayn4surf
    Socal
    Plus it looks like your upper ball joint is leaking grease...the uca with a uniball will be a great upgrade for that as well
  14. May 11, 2018 at 8:00 PM
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    So drop one notch on shocks, new UCAs. Will I still need to remove spacers?
  15. May 11, 2018 at 8:00 PM
    #35
    tcjacado
    You are going to need to trim and cut, most likely do the cab mount chop on it to clear those at full lock and stuffing it in the wheel well. Hammer them pinch welds, seal up with black rtf, then hit with some bed liner.
    Rob Daman and Prayn4surf like this.
  16. May 11, 2018 at 8:01 PM
    #36
    KaptainH
    Kris
    Gainesville, GA
    Yes
  17. May 11, 2018 at 8:01 PM
    #37
    tcjacado
    Are you level or are you leaning to one side?
  18. May 11, 2018 at 8:01 PM
    #38
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Yeah uhhhhh that doesn't look right at all. Are your spring piecesp upside down? There's absolutely no way it should sit that way
    Grey 2015 and tcjacado like this.
  19. May 11, 2018 at 8:01 PM
    #39
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    Will do. I kind of figured I’d have to.
  20. May 11, 2018 at 8:02 PM
    #40
    loaderman82
    Dalton
    Flippin, AR
    2008 Off-Road
    I’m pretty level the way it is now
