Did I likely damage the Taco 4WD?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stephenkd, Aug 21, 2022.
  1. Aug 21, 2022 at 7:41 AM
    stephenkd
    stephenkd [OP] Member
    Hi guys:
    New Taco owner here and first time 4WD owner. I JUST found out about the whole deal where you aren't supposed to drive in 4WD on dry pavement (and know I understand all the reasons why, thanks to some YT vids that explain everything).
    Up until I found this out, I would periodically switch the taco into 4Hi and drive maybe 30 yds or so (on dry road of course).
    1) Did I likely damage anything?
    2) Since the owners manual wants you to drive in 4H periodically every month to keep things lubricated (and I never will be offroading), is it okay to do just what I did, namely, drive maybe 50yds in a straight line in 4H (dry pavement, the only thing around me), or is that a garunteed transfer case binding situation?
    3) Also noticed that 4H only seems to want to engage and disengage when in DRIVE and moving slowly. The 4WD light keeps blinking if I'm at a complete stop or in neutral. Is this normal?
    Please help. freaking out.. :(
    Gtazz67, ExGunner and wilcam47 like this.
  2. Aug 21, 2022 at 7:42 AM
    anotherreject
    anotherreject Well-Known Member
    Straight line on dry pavement did not hurt anything
  3. Aug 21, 2022 at 7:43 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You’re fine. Straight line driving on dry pavement won’t hurt anything.
    AZ Pete, KY_Rob, musicisevil and 3 others like this.
  4. Aug 21, 2022 at 7:43 AM
    Ajsmith1990
    Ajsmith1990 Well-Known Member
    2016 Quicksand Tacoma OR DCSB
    Straight line is fine. Just don’t want to be taking corners on pavement. It’s good to click it in like you did just to get things moving. If you ever turn on dry pavement slow you’ll know the feeling of why it’s not good immediately lol. Happy driving
    ArchedRegant and wilcam47 like this.
  5. Aug 21, 2022 at 7:46 AM
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Ditto to the above responses, don’t exceed 45 mph (that’s me) try for a mile, this will circulate the fluids and heat it up to drive our any moisture. Enjoy the new toy.
  6. Aug 21, 2022 at 7:49 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    4WD and dry pavement don't mix... if you can't find a dirt road do it in a straight line for a short distance on wet pavement. The main concern is binding up when turning.
    wilcam47 likes this.
  7. Aug 21, 2022 at 7:51 AM
    Tac2021
    Phil
    none yet
    One last answer, the blinking light means the gears and splines are waiting to mesh, no big deal. Sometimes it will mesh up at a stop but more so you need to be rolling. Sometimes you may read about trucks stuck will off road and can’t engage because of that.
    SR-71A, cryptolime and wilcam47 like this.
  8. Aug 21, 2022 at 7:59 AM
    stephenkd
    So everyone here is saying that short distance, straight line is okay for dry pavement, but I thought that was still bad because there is no center differential that allows the front and read wheels to spin at different rates. So, did I likely mess anything up going about 50yds in a relatively straight line in 4H???
    So worried...
    Gtazz67 likes this.
  9. Aug 21, 2022 at 8:05 AM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    The answer is still NO, as mentioned in every previous post. You can stop worrying. Everything is ok.
    mtip, KY_Rob, DaBigDogg and 5 others like this.
  10. Aug 21, 2022 at 8:05 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    When mechanical systems break, you know it. What is it you think you would have damaged? If something binds, it breaks or it doesn’t.
    Everyone likes to talk about what could happen but everyone fails to mention anyone who has ever had something happen.
    Bleep100, SR-71A, 0xDEADBEEF and 2 others like this.
  11. Aug 21, 2022 at 8:05 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Stop worrying. Its fine. Its the sharp turns on dry pavement in 4x4 thats bad.
    musicisevil and shakerhood like this.
  12. Aug 21, 2022 at 8:07 AM
    Sean42
    Sean42 Well-Known Member
    If it doesn’t feel or sound broken nothings broken from driving in 4WD on pavement for a short time
  13. Aug 21, 2022 at 8:08 AM
    OffroadToy
    It's not the best option (you need slippage) but if that's your only way to engage 4WD once in a while it's better than nothing. You didn't hurt a thing... just be sure to go straight and if you can wet pavement is better than dry.
  14. Aug 21, 2022 at 8:11 AM
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    i drive in 4x4 a few times over the summer if i am spending most of my time on highways just to "exercise" the system. 1/2 my drive to the office, about 20km, is dead straight 2 lane road so that's when i'll engage it. I'll turn it off before i have to make my turns.
    mtip, Irons and SWPA Tacoma like this.
  15. Aug 21, 2022 at 8:12 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    You ever watch tremors where they are driving the 4wd jeep and the graboid catches the jeep and they put it in 4wd and the wheels hop on the concrete? That's what you don't want happening. Otherwise you are fine.
  16. Aug 21, 2022 at 8:15 AM
    stephenkd
    Thanks guys! You are the best! Love the Tacoma. :)
    DaBigDogg likes this.
  17. Aug 21, 2022 at 8:16 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    They are not spinning at different rates when you are driving straight. Only when turning and you will feel the resistance in your steering wheel when turning in 4WD, even on dirt roads if the dirt is hard.
    I have owned many 4x4s, including three Tacomas... none have failed because I used 4WD on pavement driving straight.
    shakerhood likes this.
  18. Aug 21, 2022 at 8:22 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    It takes a lot more to damage things. Just think of how people abuse their trucks off-roading. What you’re doing (even if you’re cornering) didn’t do anything.
    02Duck and soundman98 like this.
  19. Aug 21, 2022 at 8:29 AM
    OffroadToy
  20. Aug 21, 2022 at 8:29 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Now put it in 4L, turn on the locker, and gun it on dry pavement and do sweet wheelies and doughnuts!:burnrubber::bikewheelie:
