Did I make a mistake buying a 2011 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DTL54, Jul 12, 2025.
  1. Jul 13, 2025 at 4:58 AM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    need one of every generation at that age!!
    RockinU and DTL54[OP] like this.
  2. Jul 13, 2025 at 5:15 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I look at it this way. We are all going to be dead a long time . So no matter how old you are , do everything and anything you enjoy if you have the means. Obviously certain family obligations come first , but if you enjoy stuff like this and feel good why not . 80… 90 ….
    DTL54[OP] likes this.
  3. Jul 13, 2025 at 7:59 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Nice truck ! Maintain it and coat the frame and you will be golden !
  4. Jul 15, 2025 at 6:50 AM
    DTL54
    DTL54 [OP] Well-Known Member
    2001 Tacoma 4WD ext cab, 2011 Tacoma access cab 4WD TRD Sport
    Stainless steel drain plugs, Hankook tires
    I was noticing the 2011 have a rear spring issue. They say if you notice 3 leaf pack clamps it is still the suspect spring. There was a recall for one of the leafs braking and pivoting into the brake line or gas tank. If you notice 4 clamps it is the replacement spring. I looked up my VIN # on the Toyota recall sight and it showed no open recalls but in the pictures of my truck I see 3 spring clamps not the 4 there is supposed to be.I also see conflicting information about the number of clamps indicating a replacement spring.
  5. Jul 15, 2025 at 12:04 PM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    Congrats on the new truck! Here's my 2011 ACLB. 173k miles, so far the rust is manageable.
    Steves104x4 likes this.
  6. Jul 15, 2025 at 1:52 PM
    DTL54
    It looks great! Can you carry much of a load without the rear end sagging? On my 2001 4WD I had to get some off road springs that when added to the stock springs lifted it about 1.5" or so and I was then able to load the bed up with as much as I wanted without it sagging. What brand of cap do you have on the back? What state are you located in? That looks like a Wisconsin "work Zone" sign!
    lowmower likes this.
  7. Jul 16, 2025 at 6:48 AM
    lowmower
    Benji
    2011 Pyrite Mica V6
    I have air bags for any extra load, it doesn't do too bad though. I've heard it's worth upgrading rear leafs if you plan on carrying any load. The topper is a Unicover Legend, it's great but the clear coat is starting to peel in some places. I really like having it because it makes the bed storage more secure. That pic was taken in Michigan's UP, I just moved to the northern Lower Peninsula from Marquette last month.
  8. Jul 20, 2025 at 11:14 PM
    DTL54
    Trail 1b.jpg Trail 2b.jpg Well I took delivery of the truck. It cost $1000 but it was the easiest 1200 mile trip I never took :) It would have easily cost that much for the plane ticket and gas for the drive home. But I admit buying without seeing it in person was a gamble.I had all the pictures plus pictures of the under carriage.I had the Carfax which showed this truck was well taken care of and this dealer usually only offers vehicles in nicer shape but you pay for that. The frame is spotless. I ran it through the car wash and barely even light dust remained inside the frame rails. Very light surface rust on the original exhaust was the only corrosion.
    I believe the roof was repainted as someone here mentioned the sun is a paint killer in NM. The tops of the fender flairs have clear coat degradation a bit also. If it bothers me I have a friend who could touch up that.
    The delivery driver mentioned he has never transported a Tacoma with a 6 speed manual transmission before. It's a lot of fun to drive and the clutch was replaced at 110k. The Carfax shows the owner was meticulous about changing the oil every 5k miles.
    There is a Toyota guy on You Tube ,"The Car Care Nut", who is a certified Toyota tech who points out on the 4.0 ltr V6 it is worth it to change the oil every 5k . Something about how the VVT system works best with clean oil. That and proper coolant maintenance make it the 500k motor. So I might preemptively change the water pump and all the serpentine idlers and all the stuff that goes along with that. Also going to change out all the trans and differential oils with synthetic and replace the filler plugs with stainless for the Wisconsin winters before getting the under coating sprayed on before winter.
    I was looking at taking it to a NHOU under coating place. They look like they do a pretty thorough job.
    I was lucky enough to have a corn field across the road from me since 1990 when I built my house.2 years ago that ended! :(
    Hay Lobos and lowmower like this.
  9. Jul 21, 2025 at 5:09 AM
    lowmower
    Benji
    2011 Pyrite Mica V6
