Did I miss anything on my lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JayRolla, Feb 27, 2021.
  1. Feb 27, 2021 at 7:52 PM
    JayRolla
    JayRolla [OP] Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Finally purchased a lift for the wife's 2nd gen. Everything is on backorder and going to take months to ship. Fun stuff! Anyways did I miss anything?
    2012 Tacoma DCSB 4x4 SR5
    Front:
    Fox 2.0 Coilovers
    Wheelers superstop bumps stops
    Wheeler's 3/8" Strut Top Plate Spacer for taco lean
    Rear:
    Allpro expedition 3-4" leaf springs
    Fox 2.0 performance reservoir extended shocks
    Wheeler's U-bolt Flip Kit
    Wheeler's Extended Rear Brake Lines
    Wheeler's superstop bumpstops
    Carrier bearing drop kit
    Thanks guys for any help..
  2. Feb 27, 2021 at 7:59 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    You may not need the carrier bearing drop. Everything else looks pretty solid.
    i have a similar set up and haven’t needed the carrier bearing drop but another 50% would argue the opposite.
    did you get stainless steel brake lines for the front too?
    JayRolla[OP] likes this.
  3. Feb 27, 2021 at 8:16 PM
    JayRolla
    Colorado Springs
    No but might as well get fronts. I know they are not needed but SS doesn't swell like rubber even braking.
    Skootter14[QUOTED] likes this.
  4. Feb 27, 2021 at 8:17 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Uca’s?
    Spizike231 likes this.
  5. Feb 27, 2021 at 8:20 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Grease for the lead springs
    Maybe axle shims
  6. Feb 27, 2021 at 8:21 PM
    Skootter14
    Jeremy
    Do the 2.0s provide the same lift potentially requiring UCAs for the caster adjustment?
    Add: I used 3* axle shims for a 3 leaf AAL to OEM leafs, but I have not needed the shims for the AllPro standard leafs. Ran them for a little bit and actually just installed the expo pack today.
  7. Feb 27, 2021 at 8:22 PM
    Bishop84
    Bishop84 Well-Known Member
    Pretty much an ideal setup in my eyes. I don't do shims or drops unless there's a driveline issue personally.
    Upper arms are always ideal but add them later if you plan on 285s with 32's they can wait.
    TnShooter and Skootter14 like this.
  8. Feb 27, 2021 at 8:25 PM
    Skootter14
    Jeremy
    this
  9. Feb 27, 2021 at 8:36 PM
    JayRolla
    Colorado Springs
    They don't require UCAs due to not being extended but still lose caster.
  10. Feb 27, 2021 at 8:39 PM
    JayRolla
    Colorado Springs
    I guess to keep the same preload on both springs for matching characteristics but you are right. I could just adjust the coil a few turns.
    whatstcp[QUOTED] likes this.
  11. Feb 27, 2021 at 8:43 PM
    Skootter14
    Jeremy
    On the fox 2.5s I adjusted the driver side a little higher to offset the lean.
    If you can do that with the ones you got, I’d do that.
    I THINK the 2.5s were 2 turns on the ring equated 1/4”.
  12. Feb 27, 2021 at 8:54 PM
    Skootter14
    Jeremy
    (Leaf pack should come with bushing and metal sleeves)
    whatstcp and JayRolla[OP] like this.
  13. Feb 27, 2021 at 9:23 PM
    Skootter14
    Jeremy
    Make sure your stuff doesn’t arrive damaged either. In the pic above, look at the left front side of the nearest leaf pack. You’ll notice one side of the “clamping” band around the leafs is broken off. Inspect them when you get it. UPS throws these around as they are like 71 pounds.
    took me an extra week to get a replacement but all-pro/wheelers/trailgear were good about getting a new one sent out to replace it.
    just be aware. Little scrapes and stuff are expected and fixed with black spray paint (prevent rust) but structural damage is not supposed to happen.
  14. Feb 27, 2021 at 9:35 PM
    JayRolla
    Colorado Springs
    Yeah I expect scuffs. Thanks for the info. How do you like your springs? Standards or expectations? I went with expos since we often load up our 650lb ATV and gear.
  15. Feb 28, 2021 at 7:35 AM
    Skootter14
    Jeremy
    I liked the standards until I got the HC rear bumper and kept the 35” tire on the swing out. It became too much weight for a nice ride. I’ve only had the expedition pack on for a day and only took it for a short test drive but def like it; truck rides much better.
    JayRolla[QUOTED][OP] likes this.
