Did I ruin my engine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by josh0724, Aug 25, 2018.
  1. Aug 25, 2018 at 12:09 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    its a Toyota Tacoma not a Ford don't worry
  2. Aug 25, 2018 at 12:38 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    As Forrest Gump would say: "Stupid is as stupid does" Seriously, hope your motor is OK
  3. Aug 25, 2018 at 12:44 PM
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    I’ve always ran my vehicles about that long or less about the time to clean up and put everything away never had any issues with any of the vehicles, what’s the reasoning for not running a vehicle that long after an oil change?
  4. Aug 25, 2018 at 12:45 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    If you have leaks or aren’t building pressure you won’t blow your engine.
  5. Aug 25, 2018 at 12:47 PM
    crisanalex
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    Lol, good info would suck to learn the hard way. Thanks
    diabetiktaco[QUOTED] likes this.
  6. Aug 25, 2018 at 12:55 PM
    gurneyeagle
    gurneyeagle Well-Known Member
    Saint Augustine, FL/Houston, TX
    2008 Tacoma SR5, 2018 Audi TT RS, 2018 Tacoma TRD Off Road (Cement), 2019 MDX
    You'll be fine. The engine wasn't put under any load. Just drain all the oil, change the filter, and refill to proper level. Mistakes happen, move on.
    LOL at those with apparent reading comprehension issues. Do you guys even read the posts before replying? Jeez!
  7. Aug 25, 2018 at 1:03 PM
    crisanalex
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    The reason why I haven’t been on TW lately it seems the newest trend is how much of an idiot can we make the next guy look. Hope the engine is fine OP.
    Naumoff42, VirusCage, 1bad2k and 6 others like this.
  8. Aug 25, 2018 at 1:12 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Where did you learn that rule?
    Running Board Man and Crodell6 like this.
  9. Aug 25, 2018 at 1:13 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Common sense taught that to me.
  10. Aug 25, 2018 at 1:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ok hang on. I want to hit pause on this thread for a second because no one has asked, what that other oil he drained out was.
    OP, you may want to check your transmission fluid level right now before you drive it, because if you did drain out oil and double filled your engine you pulled the classic drained the tranny pan dry and filled the engine oil thinking you did an oil change mistake that happens on the forum every once in a while.
    eon_blue and Crodell6 like this.
  11. Aug 25, 2018 at 1:22 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I think you be okay. Just drain oil pan and fill again with new filter.
    Yeah and check you tranny.
  12. Aug 25, 2018 at 1:24 PM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    If I am understanding his post correctly he drained just the filter, not any oil from any pan but I could be wrong.
    Spare Parts and shakerhood like this.
  13. Aug 25, 2018 at 1:26 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Nice! A self-taught intellectual titan!
    Hobbs and Crodell6 like this.
  14. Aug 25, 2018 at 1:28 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Think of it. OP has a concern. His concern also could have been wrong oil, not enough oil, where is the oil, did I put oil in, etc. We all have brain farts. If you run the vehicle for 30 seconds before rechecking the level you'd have done 4:30 less damage than letting it run for 5 mins. Anything less than 30 seconds may not be enough time for pressure to fully build etc.
    MFTAF13 and boynoyce like this.
  15. Aug 25, 2018 at 1:32 PM
    #35
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    That is more so my thinking (not enough time to build up realistic oil pressure), but you make a good point.
  16. Aug 25, 2018 at 1:34 PM
    #36
    josh0724
    josh0724 [OP] Well-Known Member
    Josh
    2017 Quicksand Tacoma TRD Off Road
    That's correct. I initially only drained from the filter, not the pan. I'm almost positive I didn't drain the transmission but after today, it wouldn't put it past me lol. I'll double check.
  17. Aug 25, 2018 at 1:37 PM
    #37
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sounds to me like the OP just had a bad morning and forgot to pull the drain plug and only drained the filter
    boynoyce and 12TRDTacoma[QUOTED] like this.
  18. Aug 25, 2018 at 1:42 PM
    #38
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Just for clarification, the first part was a joke to anyone who didn't know.
    Sweets and Running Board Man like this.
  19. Aug 25, 2018 at 1:43 PM
    #39
    SWB Tacoma
    Arkansas
    Your not going to have more oil pressure just because you have more oil. Your down fall is you did not have splash from crankshaft hitting pool of oil bottom of pan because it was submerged in oil. Crankshaft splash is for parts above crankshaft to help lubricate.
  20. Aug 25, 2018 at 1:46 PM
    #40
    BillsSR5
    bill
    2014 SR5
