Did I ruin my engine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by josh0724, Aug 25, 2018.
  1. Aug 25, 2018 at 1:47 PM
    #41
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    If some one is dumb enough to follow those stupid directions, well I guess as some one already said, stupid is as stupid does.
  2. Aug 25, 2018 at 2:35 PM
    #42
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Let it be and go 20,000 miles before your next oil change? :notsure:
    Spare Parts and josh0724[OP] like this.
  3. Aug 25, 2018 at 2:35 PM
    #43
    josh0724
    josh0724 [OP] Well-Known Member
    Josh
    2017 Quicksand Tacoma TRD Off Road
    I did but apparently it's only good until 25k miles.
  4. Aug 25, 2018 at 2:48 PM
    #44
    Bishop84
    Bishop84 Well-Known Member
    I've seen it before on a 2GR, caused a huge misfire, the problem went away once the level was evened out.
  5. Aug 25, 2018 at 2:58 PM
    #45
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Does anyone know exactly what happens to your engine if you overfill (substantially) and why it will damage your engine?
    First one to get it right wins 100 internet points to spend at a website of your choice..
    Running Board Man likes this.
  6. Aug 25, 2018 at 3:04 PM
    #46
    Hank Heel
    Hank Heel Well-Known Member
    WA
  7. Aug 25, 2018 at 3:09 PM
    #47
    Spare Parts
    Southern Maine
    Screws with the oil pump pressure and then oil pump doesn't work, thus no oil pressure.
    hiPSI[QUOTED] likes this.
  8. Aug 25, 2018 at 3:12 PM
    #48
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Go find my point in the other post. Then, if you decide you still feel like being a cunt you may argue with me.
    Tacomamike mike and boynoyce like this.
  9. Aug 25, 2018 at 3:12 PM
    #49
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Close. There are antifoam additives included in the additive pack in your oil so no foam. Your crank will aerate the oil and make honest to goodness big bubbles. Your oil pump will now suck a combination of air and oil or "froth" as you say. Now instead of key areas having oil as lubrication you could have air as lubrication. Not good, as this will lead to heat and metal on metal contact, as there is no more boundry layer.
    OP, the good news is there was no load. The bad news is you let it run for five minutes.
    You could have shortened the life of your engine substantially and you won't know it until later. Or, it might have no damage. The only way to truly know is take it to a shop and let them examine a few key parts for accelerated wear. Sorry man and good luck.
    100 points to @Jamesboy2233!
  10. Aug 25, 2018 at 3:21 PM
    #50
    VTbuckeye
    VTbuckeye Active Member
    Joseph
    Red 17 Tacoma TRDsport DCSB MT
    Blackstone? Check for excessive wear indications after you drive for a bit?
  11. Aug 25, 2018 at 3:28 PM
    #51
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    It will be fine
    2016Tacoman, boynoyce and Hank Heel like this.
  12. Aug 25, 2018 at 5:14 PM
    #52
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I seriously doubt that 5 minutes was long enough to aerate the oil to a degree that you lost oil pressure, and if you did I would think the oil pressure alert indicator would be screaming at you.
    I wouldn't worry at all.
    Hank Heel and josh0724[OP] like this.
  13. Aug 25, 2018 at 5:24 PM
    #53
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    You may have ruined some seals.
  14. Aug 25, 2018 at 5:30 PM
    #54
    2016Tacoman
    J
    Why ? :confused:
  15. Aug 25, 2018 at 5:33 PM
    #55
    e6400ultra
    NorCal
    Overfilling oil is the leading culprit for a blown main-seal, for a start. ...And the OP really, really, really overfilled. Keep an out for seeping oil on your seals, OP.
    ian408 likes this.
  16. Aug 25, 2018 at 5:46 PM
    #56
    gitacotrd
    gitacotrd Well-Known Member
    Marc
    Texas
    2018 Cement TRD offroad
    Avid lightbar, Eibach 2in lift, various TRD parts
    Delete this shit... drain the oil. Fill it with the correct amount and cross ur fingers it didn’t:
    • Engine damage such as bent rods in the engine or collapsed valve pipes.
    • Catastrophic engine failure where the engine sustains enough damage that it cannot be repaired, but must instead be replaced.
    • Excess engine wear from inconsistent oil pressure over time.
    • Spark plug fouling, resulting in the need to replace spark plugs more frequently.
    • Excess oil deposits in the catalytic converter.
    If you got:
    • Oil leaking from your car
    • Smell of burning engine oil
    • Smoke from the engine compartment
    • Smoke or black exhaust from the tailpipe
    • Unusual noises coming from the engine
    Go get it looked at... don’t tell them what u did lol
  17. Aug 25, 2018 at 5:54 PM
    #57
    2016Tacoman
    J
    If you were doing 100 mph and the pressure rose from excessive blowby due to a bad pvc not venting maybe. How did his pressure rise in the crankcase in the driveway at less than 1000 rpm ? What happened to front main seal ?
    No way.
  18. Aug 25, 2018 at 6:05 PM
    #58
    e6400ultra
    NorCal
    Rear main usually goes first. Time will tell.
  19. Aug 25, 2018 at 6:18 PM
    #59
    josh0724
    Josh
    I got it out and up to 60mph without any issues. Popped the hood when I got home with it running and nothing out of the ordinary so maybe I'm in the clear. :fingerscrossed:
  20. Aug 31, 2018 at 2:07 PM
    #60
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    truth! Im in a 16 with 40k miles and mine was just replaced by the dealer under the CPO 100k power-train warranty. would have been a 1k job otherwise... they have to drop the transmission
