Did I screw up my transfer case accidentally going from 4H to 4L improperly?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FunkMasterFlex, Sep 24, 2021.
  1. Sep 24, 2021 at 4:05 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Wait until you meet 6” of 30F slush on the hiway at 65 mph. It won’t matter if your tires are bald or new. :)
    Junkhead, Knute and Trail Limo like this.
  2. Sep 24, 2021 at 4:18 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    4Hi won’t always save you. You need some common sense as well. I agree with others that my truck won’t let me go into 4lo unless it’s in neutral.
    I love this vid. Especially when the cop car rear-ends the buss sliding backwards.
    https://m.youtube.com/watch?v=HrHvUeFs01s
    usmc2msu, DanoTay and gudujarlson like this.
  3. Sep 25, 2021 at 10:12 AM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Back to the OP's question and the comments about it not being possible to accidentally go from 4H to 4L while in gear and moving. I managed to accidentally do the same thing and my truck had the same symptoms. I even asked the same question on this forum almost three years ago. Glad to report ...no damage. But I certainly do not want to do it again.
  4. Sep 25, 2021 at 10:18 AM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    I go from 2wd to 4hi on the run all the time with no issues , and you have to press the selector done in order to go to 4lo
  5. Sep 25, 2021 at 10:54 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    It's the front/rear axle delta that is the problem, but same idea. Left/right is compensated for by the open diff (unless using a locker)
  6. Sep 25, 2021 at 10:58 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You don't need 4wd to drive on snow, it really all depends on where you live
    ndoldman59 likes this.
  7. Sep 25, 2021 at 10:59 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Actually, that makes sense. Thanks for the correction!
    GrundleJuice[QUOTED] likes this.
  8. Sep 25, 2021 at 12:27 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Not exactly. The front and rear are locked together so one tire on the front and one tire on the back Have to turn at the same speed.
  9. Sep 25, 2021 at 8:37 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No they don't. The sum total of the front two wheels must match the sum total of the rear two wheels because the axle inputs are what's forced equal. It's this front to rear axle totals not traveling the same net distance in turns that creates 4wd bind.
    myn75 likes this.
  10. Sep 25, 2021 at 8:47 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    i disagree. There are advantages to having your front and rear tires going the same speed for braking as well. Flame on.
    [KD] likes this.
  11. Sep 25, 2021 at 9:34 PM
    Trail Limo
    Trail Limo Well-Known Member
    It's funny you say this. I used to have an old jeep Cherokee with rear brakes so terrible that engaging 4x4 would significantly improve it's stopping ability.
  12. Sep 26, 2021 at 6:15 AM
    Dbarffish
    Doug
    Montana
    Stock
    Ha! I had a 74. Years ago - driving an old Cordoba on slick snow approaching a toll both I lightly hit the breaks and immediately went into serious fishtail. I got it under control by moving tranny into neutral. Would never happen with 4WD. There are other real world examples. Now, antilock breaks do change the situation greatly.
  13. Sep 26, 2021 at 6:45 AM
    ShimStack
    Ben
    NC
    I've covered this before and 4wd actually does improve braking performance but it's a bit of an advanced vehicle dynamics concept. It's not worth explaining since most can't even fundamentally understand how open and locked diffs work with regards to tractive forces.
    minium, G8R_Taco and Trail Limo like this.
  14. Sep 26, 2021 at 7:04 AM
    redrock95
    redrock95 Well-Known Member
    White 2012 Tacoma TRD Offroad, Manual 6-spd
    Engaging 4wd and utilizing transmission braking is absolutely beneficial in hilly/slippery terrain. While 4wd will not bring you to a stop quicker in an emergency stop scenario it will allow better traction during cornering and general breaking conditions.
  15. Sep 26, 2021 at 7:08 AM
    #35
    retrofive
    retrofive Well-Known Member
    I was trying to type something like that. Those are the words I was looking for.
  16. Sep 26, 2021 at 7:12 AM
    #36
    GrundleJuice
    Michigan
    2016 TRD Bro
    Now is your chance VVVVVVV
    Skydvrr and G8R_Taco like this.
  17. Sep 26, 2021 at 12:48 PM
    #37
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    I Just did the same thing this morning when doing my 5 miles of monthly PM on a straight road at 40 - 45 MPH. Apparently, I turned the knob the wrong way when i wanted to turn it off and it beeped at me angrily. It took a second to figure out what I did. no damage and no issues. I have done it before accidentally and no ill effects. I do not think the actuator for 4 LO will (or should not) actually engage above a certain speed, kinda like the transmission will not go into reverse when driving forward even if you attempt to do it. I think someone actually tried that and reported the rear camera came on but it did not actually go into reverse at speed.
    So I would say you are fine but do not make a habit of it.
    Also, driving in a straight line in 4WD Hi for a short distance whether on asphalt or not will not harm anything. It is the turning that stresses components and why it is advised to do it in wet weather or offroad.
  18. Sep 26, 2021 at 3:14 PM
    #38
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    It was raining this morning so I put it in 4hi for about 7 kms on my way to work. Nice straight stretch. Use it or lose it!
    FLJB[QUOTED] likes this.
  19. Sep 26, 2021 at 3:38 PM
    #39
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Don't be a twat, it's not rocket science.
    Front and rear locked together, wheels must turn same speed therefore brakes can't lock up while any wheel has traction, therefore driver can brake harder without locking up.
  20. Sep 26, 2021 at 5:10 PM
    #40
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    Transfer cases are resilient. In my Chevy 2500, towing a 13k lb 5th wheel, I twice forgot to shift out of 4wd after meeting pavement. One was in the mtn roads of CO, and I went for 150 miles and the other was a more straight 100 miles in NV. No issues ever presented. Just kick yourself and move one.
