Did I screw up my transfer case accidentally going from 4H to 4L improperly?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FunkMasterFlex, Sep 24, 2021.
  1. Sep 26, 2021 at 5:21 PM
    #41
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You probably did more damage driving in 4hi on pavement than trying to shift into 4 lo improperly. 4X4 isn't intended for wet pavement. For that you want AWD.
    Using 4X4 like that may not cause it to break right now, but you did cause excessive wear. You, or maybe the next owner, will see parts fail prematurely.
    Coming from a guy who had a transfer case rebuilt twice in just a few months. The vacuum hoses that locked the center diff on the truck I owned at the time had gotten reversed. When the switch was in 2wd I was actually in 4X4. I was in my early 20's at the time and knew better than to be in 4X4 on pavement, but not experienced enough to recognize the problem.
    everymanalion and danojeno like this.
  2. Sep 26, 2021 at 5:32 PM
    #42
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    Surely not good and probably less of an issue it being a chain driven case, but she soldiered on for many years.
    Skydvrr likes this.
  3. Sep 26, 2021 at 7:26 PM
    #43
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It was a Jeep and you drove around for months in 4x4, making hundreds if not thousands of turns on bone dry pavement.
    Skydvrr likes this.
  4. Sep 28, 2021 at 7:29 AM
    #44
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Assuming open axle differentials, the sum total angular velocity of the front wheels must match the sum total of the rear wheels but the individual wheel speeds don't need to match. But yes, this 4wd axle-to-axle constraint results in excess braking torque being distributed to the axle with traction prior to locking up.
    Trail Limo, [KD][QUOTED] and Skydvrr like this.
  5. Sep 28, 2021 at 7:32 AM
    #45
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
