Did I screw up? P0606 code
Discussion in 'General Tacoma Talk' started by Reto101, Sep 17, 2023.
  1. Sep 17, 2023 at 12:31 AM
    Reto101
    Reto101 [OP] Member
    2008 Tacoma Prerunner
    Immature? Probably. But I had a 2 hour road trip at around 2am and decided to top out my 08 Tacoma “on a closed road” and after I let off the code P0606 popped up. I have delt with codes before but this one I am unfamiliar of. Definitely took it easy the rest of the way and it drove like nothing happened? Any thoughts or advice?
  2. Sep 17, 2023 at 8:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    P0606 is an internal PCM fault, I wouldn't be overly concerned about it unless it keeps coming back.
    I have seen flaky O2 or AFR sensors cause that code to set as well but it's usually accompanied by an O2/AFR sensor code.
  3. Sep 17, 2023 at 10:59 PM
    Reto101
    Reto101 [OP] Member
    Gotcha thank you for the input. I have had O2 sensor problems last year so that could be a part of it, I’ll look into that thanks!
    Dm93 likes this.
