did I short my off road lights out?
Discussion in 'Lighting' started by rondog, Jan 30, 2012.
  1. Jan 30, 2012 at 1:24 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    I washed my truck and now one set of my offroad lights don't work...I turned them on and they flashed a couple times and now they wont turn on. I have 4 HIDs, 2 switches, and 2 lights on each switch.
    Both go through a relay to a circuit breaker and the switch. What the heck did I do? I am no electrical genius :confused:
    edit:: oh and the other lights on the other switch work fine
  2. Jan 30, 2012 at 1:26 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    sounds more like you may have loosened a ground to me
  3. Jan 30, 2012 at 1:27 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    if the light flickered then shut off sounds like the ballast is fried
  4. Jan 30, 2012 at 1:29 PM
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    check for frayed wires, i remember out in Barstow krish's lights weren't working because a bare wire contacted metal and blew the fuse.
  5. Jan 30, 2012 at 1:29 PM
    rondog
    Ronnie
    Escondido/San Diego
    hmm well I guess it can be many things...my last thread I made about my lights going out a bunch of people said it was bad ballasts for sure...turns out it was a bad relay...I'll have to look at it when im home..these lights have been such a pain in the ass
  6. Jan 30, 2012 at 1:30 PM
    08pretaco
    az
    when the relay was bad, was there a problem with only one lights again? or all lights going to the relay?
  7. Jan 30, 2012 at 1:31 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    technically you dont need relay's as long as you remember to shut off your offroad lights. :p
  8. Jan 30, 2012 at 1:36 PM
    rondog
    Ronnie
    Escondido/San Diego
    the previous issue was one set of lights on the same relay/switch kept turning off and I thought it was after a certain amount of time, but the case ended up being a bad relay because if I didnt move the truck, theyd stay on. If I flicked the relay, they'd go off. I bought a new relay for 7 bucks and they worked my entire last desert trip...so now I dont know what the issue is going to be. I can switch the relays and see if they come on with the working relay. That'll eliminate one possibilty
  9. Jan 30, 2012 at 1:38 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    eliminate the relay all together and see if it works, if not, its not the relay :p
  10. Jan 30, 2012 at 3:45 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    Process of elimination: circuit breaker, fuses, grounds, relays, switches, ballasts. Also how are they wired? You'd be surprised how many people dont know how to wire relays properly.
    Btw relays arent necessary when its low current. I would never wire up that many lights without a relay getting 12v direct from the battery using switch for ignition purpose only.
  11. Jan 31, 2012 at 9:10 AM
    rondog
    Ronnie
    Escondido/San Diego
    So I flipped em on this morning and they work again...which part along the way had water in it making it not work. It can't be the light itself. It has to be my awesome wiring job. What if the circuit breaker is wet? It seems like if the relay had water in it, that could stop it from working. All my solder points are wrapped in shrink tube so I doubt thats it
  12. Jan 31, 2012 at 9:14 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    water + electricity = bad. so they work now? problem solved right?
  13. Jan 31, 2012 at 9:22 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  14. Jan 31, 2012 at 9:25 AM
    rondog
    Ronnie
    Escondido/San Diego
    so....seal the relays? the circuit breakers? both? haha thats what I was getting at
  15. Jan 31, 2012 at 3:53 PM
    rondog
    Ronnie
    Escondido/San Diego
    Someone from eagleeye lights PM'd me about the issues I was having. Talk about some good customer service :thumbsup:
  16. Jan 31, 2012 at 4:01 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Give liquid electrical tape a shot on your connections if water is an issue (just make sure its waterproof!)
